Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 12-31-2003, 03:23 PM   #1
dimonx
Default No Idea where to start
I bought an 97 A4 1.8T Quattro about 4 months back. I also have the VAG-Com tool (excellent BTW - Good job Uwe). But I really don know where to start.
I have no fault codes (good I guess). But the car seems to be very sluggish. Delayed accelaration (intermittent).
If there a guide out there that I can follow to check and see if my engine is up to scratch. I thought it might be the MAF - since i get a reading of around 30 - but thats giving gas to the car(not actually moveing - I have the brakes on) Does this matter?
Someone please help - I dont know where to start. I love my car - and the VAG-COM tool is great - but I dont know where to start, what to look for and how to compare. I need to know if this car is running as it should. I cant even find the specs on this car.
Anyone - Someone - please....
-DIMoN | X (dXs)
::97' A4 1.8T Quattro (Stock)::
dimonx is offline   Reply With Quote
Old 12-31-2003, 05:52 PM   #2
DFWTip01
Default Re: No Idea where to start
Are the BPV's clean?
Post your question in th A4 forum, you should get a response there.
2001.5 Tip, 45k miles, ITG, Forge BPV's, AMS ECU, Borla catback, Intrax MC, snub
DFWTip01 is offline   Reply With Quote
Old 01-01-2004, 05:16 AM   #3
Uwe@Ross-Tech.com
Audiworld Premium Sponsor
2006 Audi A3
Uwe@Ross-Tech.com's Avatar
Default Start out by logging your Mass Airflow
you'll find it one one of the first few measuring block groups, it will be in g/s (grams/second). Get your motor warmed up, then log it for a full throttle run through the highest gear you dare (3rd?). At 5000-6000 rpm, under full load, you should see about 120 g/s -- 80% of the rated HP of your car -- if you're chipped and you think your car should be making 190hp, then you should see more like 150 g/s. If you see signifigantly less than 80% of your hp, then either the MAF bad or there's something keeping your motor from getting an appropriate amount of air. Next you'd have to check your boost, but since your cable-throttle engine doesn't have a manifold pressure sensor, you'll need to install an actual boost gauge to do that.
-Uwe-
http://www.Ross-Tech.com
Uwe@Ross-Tech.com is offline   Reply With Quote
Old 01-01-2004, 10:00 AM   #4
dimonx
Default Re: Start out by logging your Mass Airflow
Thanks for the info... I dont even know how much HP i should have. anyway to find out? any tech docs out there?
-DIMoN | X (dXs)
Old 01-01-2004, 11:00 AM   #5
Uwe@Ross-Tech.com
2006 Audi A3
Default A stock 1997 1.8T is 150 HP.
Old 01-02-2004, 09:07 AM   #6
dimonx
Default Re: A stock 1997 1.8T is 150 HP.
once again - Thanks for the follow-up..
-DIMoN | X (dXs)
HTML code is Off
