#1 | ||
#2 |
Audiworld Premium Sponsor
2006 Audi A3Join Date: Sep 2000
And there's no PXXXX code equivalent. If your ECU is chipped, talk to your chip-tuner.
5-Digit codes are native VAG codes. PXXXX codes are defined by the SAE. Since VAG-COM uses the native VAG protocols just like the dealer's tool, it receives native VAG codes from the car. If there's an SAE equivalent P-code number, current versions of VAG-COM will give that to you as well. -Uwe-
http://www.Ross-Tech.com |
#3 |
I've been also getting dtcs like 01371 (defined as: "alarm via door contact switch driver's side") without the PXXXX SAE equivlents. I guess this means it is only reading native VAG codes. The car is chip, hence no PXXXX readings for 64764 (?). Thanks again.
| Tags |
| 64764, audi, code, dtc, interpretation |
