Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 05-30-2003, 07:51 AM   #1
QuiksilverS4
Default keyless entry update: tried both channells 1 and 21 and both read error not available
I suspect my keyless entry controller is toast.
Any other ideas, anyone??
Here are the dtc's I cleared.
4 DTCs Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm via Door Contact Switch: Driver Side
35-00 - -
01370 - Alarm via Interior Scan
35-00 - -
00955 - Key 1 Adaptation Limit Exceeded
09-00 - Adaptation Limit Surpassed
Both Channel 01 and 21 for reprogramming remotes with VAG-COM come up as Error Not Available.
QuiksilverS4 is offline   Reply With Quote
Old 05-30-2003, 01:45 PM   #2
Uwe@Ross-Tech.com
Audiworld Premium Sponsor
2006 Audi A3
Uwe@Ross-Tech.com's Avatar
Default OK, it seems that on your car,
the matching is done with the kludgy "2-key, outside the car" method. It's a bit too complicated to post here, but you'll find it on the Bentley CD.
Check your e-mail too.
-Uwe-
http://www.Ross-Tech.com
Uwe@Ross-Tech.com is offline   Reply With Quote
01, 21, audi, channel, keyless
HTML code is Off
