S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Tech question - what is orange fluid (leaking on my garage floor)
Old 10-10-2008, 12:00 PM
Audi Advocate's Avatar
Default Tech question - what is orange fluid (leaking on my garage floor)
It's oily in feel but orange/yellow in colour.
About a quater sized patch once a week - coming from mid area of the engine.
Is that too far back to be coolant?
Brake fluid??
Thanks!
Old 10-10-2008, 12:18 PM
brit78's Avatar
The coolant is a more reddish color. Sounds like the coolant area for drippings though.
Old 10-10-2008, 01:14 PM
RVTS4's Avatar
Default Re: Tech question - what is orange fluid (leaking on my garage floor)
Auxilary radiator leak....mine leaked within one week of ownership, but it was CPO and also had remainder of warranty left.
Old 10-10-2008, 01:39 PM
AudiWorld Expert
S4iowa's Avatar
Default Are you not running the belly pan? This should catch any leaks and you wouldn't see it
There are only 3 things a red/orange colored fluid could be
transmission
coolant
motor mounts
the belly pan should cover pretty much the entire underside of the motor... it has to be pretty far back to leak on to the ground
Old 10-10-2008, 03:21 PM
banana s4's Avatar
motor mount? or is that red
Old 10-10-2008, 06:42 PM
brit78's Avatar
Aux Rad leak would be in front of the front tires. He said below the middle of the engine.
Old 10-10-2008, 07:20 PM
SNAFU 4's Avatar
Default I would put money on coolant...
Both of my aux rads went... in fact in the shop right now getting the driver's side done. Coolant is oily, and I would get quarter sized drops every so often.
Old 10-10-2008, 08:00 PM
RVTS4's Avatar
Default Re: Aux Rad leak would be in front of the front tires. He said below the middle of the engine.
True, mine did that..drip in front. But I park on a slight downhill grade..so the fluid goes that direction. If he is on level ground or a slight upgrade....then its possible for the fluid to come out another place. Thats all I was saying....when i got it repaired, they did not put a price on it...just warranty repair. I am curious how much it actuallt cost though.
Old 10-11-2008, 01:14 PM
Default Thanks guys - will take it in this week - appreciate the suggestions
Makes it a lot easier talking to the Tech guy.
Cheers
mikehbgQ5
Q5/SQ5 MKI (8R) Discussion
12-12-2009 05:08 PM
champ1
A4 (B7 Platform) Discussion
01-31-2007 10:12 AM
EzAudi
TT (Mk1) Discussion
17
11-21-2006 12:05 PM
coocoomike
10-04-2006 03:22 PM
Fangit
9
09-03-2002 11:20 AM
Quick Reply: Tech question - what is orange fluid (leaking on my garage floor)
