Help! Removing center cap on AVUS wheels
How do I remove the AVUS center cap with the ring hook? The manual says: "with the hook pin engaged,..." What does that mean?
Sorry, it's my first Audi.
Look in the trunk
Under the deck lid, left side of the tire. There is a wire ring in the black kit. Insert the end of the ring into the hole on the black ring of the cap. Pull the cap off.
Just stick it in!
Insert the end of the pin into the hole.
Make sure you insert it far enough to "hook" the pin against the inside of the cap (the pin thingy is bent or curved, if I recall).
Then just pull -- it should pop off easily.
