Go Back   AudiWorld Forums » Regional & ACNA Discussion » Pacific Northwest Discussion
Old 01-05-2009, 10:37 AM   #1
Dori/S4
Member
Default On Topic!! Having turn signal problems....suggestions puhhh-hleazze..
When I turn on signal it lights up 1 or 2 times then nothing = GREAT! ;-(
P/S HAPPY! NEW YEAR!
R.I.P. Mr. Litigation Smurf...I will miss you.
Dori/S4 is offline   Reply With Quote
Old 01-05-2009, 10:47 AM   #2
Marx
Default your relay switch is busted
contrary to popular belief, its not your blinker fluid.
Marx is offline   Reply With Quote
Old 01-05-2009, 10:48 AM   #3
Avantugofast
Default replace hazard switch/button, the relay is connected to it. Mine did the same thing!
2001 B5 S4 Avant
Avantugofast is offline   Reply With Quote
Old 01-05-2009, 11:11 AM   #4
Dori/S4
Member
Default Were your hazard lights still working, mine are.??
Old 01-05-2009, 11:19 AM   #5
Avantugofast
Default Yes hazard still worked, it's the relay components for the turn signals that go bad (in hzrd rly bx)
the only other thing it could be is loose turn signal bulbs.
2001 B5 S4 Avant
Old 01-05-2009, 11:28 AM   #6
Dori/S4
Member
Default ..uhh-hmm..so sorry but, "we're" used to working on 911's <nose-up-in-air.> Where's
the relay box located? ;<)
Old 01-05-2009, 11:33 AM   #7
Avantugofast
Default it is connected/behind the hazard relay button (assuming you have a b5?)
you have to pull off the trim piece and then pull out the hazard switch and unplug it. That's it iirc.
2001 B5 S4 Avant
Old 01-05-2009, 11:36 AM   #8
UrbanAssaultAudi
1988 Audi 90
Default your car is starting to fail
the lights are the first thing to go...
I will buy it for $350.00, that seems to be the going rate for Nogaro, yes?
I have no insight for your blinker fluid issue. You did check the level didn't you?
UrbanAssaultAudi is offline   Reply With Quote
Old 01-05-2009, 11:40 AM   #9
Dori/S4
Member
Default !!HappyPessimisticNewYear2U2Baby!!
-whoa!-
Old 01-05-2009, 11:49 AM   #10
Dori/S4
Member
Default b5=yes=teh BESTEST! & FASTEST! ;-P
