Go Back   AudiWorld Forums » Regional & ACNA Discussion » Pacific Northwest Discussion
Old 12-06-2003, 03:59 PM   #1
Negative459
Junior Member
Default My CEL came on last night. Took my chipped ECU out and now it's not on anymore. Any ideas?
Should I take it in to have it checked? Does my chipped ECU just have a code that needs cleared or could the extra power from the chip be tripping the CEL because something in my engine's about to go?
Negative459 is offline   Reply With Quote
Old 12-06-2003, 04:33 PM   #2
Josh@StatusRacing
Guest
Posts: n/a
Default codes are stored on each ECU
Old 12-06-2003, 05:15 PM   #3
Steveo369
Default Yup. If the problem is recurring, the CEL will come back on shortly...
You should probably have checked the codes prior to pulling the ECU, but you could put the old ECU back in and the code should still be there, IIRC.
AIM: Steveo369WA
Steveo369 is offline   Reply With Quote
Old 12-07-2003, 01:45 AM   #4
Negative459
Junior Member
Default Re: Yup. If the problem is recurring, the CEL will come back on shortly...
Certainly would have checked if I had the means. I have no VAG though and I didn't wanna trouble anyone with one for such a thing before I had a better idea of what may be going on. If I pop the chip back in and the CEL still shines I'll prolly just roll around stock until the next GTG or something. :-\
Old 12-07-2003, 09:17 AM   #5
Jason Chen
Default I have Vag if you need help, but I dont' have a laptop only from home :(
Sigless
Jason Chen is offline   Reply With Quote
Old 12-07-2003, 10:54 AM   #6
Negative459
Junior Member
Default Thanks but the CEL just came on with the stock ECU so something's obviously not right :-(
It's stumbling at Idle now, too. It's going in tomorrow morning.
Old 12-07-2003, 08:00 PM   #7
Jason Chen
Default Sounds like Coilpack is dead.
Sigless
Old 12-10-2003, 06:52 PM   #8
Negative459
Junior Member
Default Was on for 4 days and now it went off again. Damn thing's going in on Friday.
Old 12-11-2003, 08:45 AM   #9
Jason Chen
Default You can still come by and I'll vag it for ya.
Sigless
Old 12-12-2003, 05:53 PM   #10
Negative459
Junior Member
Default Verdict is a bad EGT sensor causing the MAF to make the engine run rich
Convered under warranty. Get it back tomorrow.
