Go Back   AudiWorld Forums » Regional & ACNA Discussion » Canadian Discussion
Old 09-09-2008, 02:24 PM   #1
Jet Jockey/A4 Pilot
Default Owners with a 2.0TFSI...Help wanted in finding out about a technical spec on the 2.0T FSI...
Does anyone know for sure of what material the 2.0TFSI's block is made of?
I know on the 1.8Ts it is iron made block but just curious if Audi finally went with aluminium on the 2.0TFS
TIA
Quarter mile in 13.3 seconds at 107.3 MPH!
Jet Jockey/A4 Pilot is offline   Reply With Quote
Old 09-09-2008, 02:28 PM   #2
afretes
Send a message via MSN to afretes Send a message via Skype™ to afretes
Default Tanner posted a pretty interesting link a few months ago that showed the company that...
made the engines for Audi
Alex Fretes
ABS
Email me for more details on VWs and Audis
afretes is offline   Reply With Quote
Old 09-09-2008, 02:33 PM   #3
afretes
Default More info...
Four Cylinder, Four Valve, FSI Turbocharged
Gasoline Engine
Engine Block
- Cast Iron Crankcase
- Balancer Shafts in Crankcase
- Forged Steel Crankshaft
- Sump-Mounted Oil Pump --
Chain-Driven by
Crankshaft
- Timing Gear Chain --
Front End of Engine
- Balancer - Chain-Driven at Front End of Engine
Cylinder Head
- 4-Valve Cylinder Head
- 1 INA Intake Camshaft Adjuster
Intake Manifold
- Tumble Flap
Fuel Supply
- Demand Controlled on Low and High-pressure Ends
- Multi-Port High-pressure Injector
Engine Management
- MED 17 Engine Control Module
- Hot-Film Air Mass Flow with Integral Temperature
Sensor
- Throttle Valve with Contactless Sensor
- Map-Controlled Ignition with Cylinder-Selective,
Digital Knock Control
- Single-Spark Ignition Coils
Turbocharging
- Integral Exhaust Turbocharger
- Charge-Air Cooler
- Boost Pressure Control with Overpressure
- Electrical Wastegate Valve
Exhaust
- Single-Chamber Exhaust System with Close-Coupled
Pre-Catalyst
Combustion Process
- Fuel Straight Injection
Alex Fretes
ABS
Old 09-09-2008, 02:45 PM   #4
jason in toronto
Default i can't find the link
[img][/img]
jason in toronto is offline   Reply With Quote
Old 09-09-2008, 02:55 PM   #5
Jet Jockey/A4 Pilot
Default Thanks Alex. It seems they are still using a cast iron block.
Old 09-09-2008, 03:21 PM   #6
1.8TQ99.5
Member
1.8TQ99.5's Avatar
Default Yes - it's actually right on their website
Right under Detailed Specs - Engine:
Cylinder Block: Cast Iron
Cylinder Head: Aluminum Alloy
A41.8T99.5quattrotipbrilliantblackapr91octaneh&rraces4bilsteinsbaileydv30k&nfilterawecenterventboostgauges4wheellinerRS4grillGentexNVSautodimmingmirror
1.8TQ99.5 is offline   Reply With Quote
Old 09-09-2008, 03:32 PM   #7
Jet Jockey/A4 Pilot
Default Thanks I did not go there thinking they would go that deep into the specs.
Old 09-09-2008, 04:35 PM   #8
Tanner
Default You got mail
Tanner is offline   Reply With Quote
Old 09-09-2008, 04:38 PM   #9
Tanner
Default Forgot this also....
Old 09-09-2008, 05:09 PM   #10
Carmine_S4
Default Who? Toyota?
_________________________________________
Photo by Eshel "Cazzo Lungo" Zweig
AW Canada PW 2007
Carmine_S4 is offline   Reply With Quote
ea888, programme, selfstudy, study, tfsi
