Go Back   AudiWorld Forums » Regional & ACNA Discussion » Canadian Discussion
Old 06-08-2007, 04:49 PM   #1
Ed@mtl
Ed@mtl's Avatar
Default Great, first issue with the car. Engine is spudding at idle, no more than 3-4psi of boost. Arggg..
No CEL. Could be a boost leak.
Ed@mtl is offline   Reply With Quote
Old 06-08-2007, 07:52 PM   #2
Meegis
Meegis's Avatar
Default MAF may be messed up
Meegis is offline   Reply With Quote
Old 06-09-2007, 05:22 AM   #3
Ed@mtl
Ed@mtl's Avatar
Default CEL just came on...
7 Faults Found:
004243 - Bank 1; Fuel Measuring System 2: Malfunction
P1093 - 008 - Implausible Signal - Intermittent
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - Lower Limit Exceeded
000769 - Cylinder 1: Misfire Detected
P0301 - 002 - Lower Limit Exceeded
000771 - Cylinder 3: Misfire Detected
P0303 - 002 - Lower Limit Exceeded
000772 - Cylinder 4: Misfire Detected
P0304 - 002 - Lower Limit Exceeded
000770 - Cylinder 2: Misfire Detected
P0302 - 002 - Lower Limit Exceeded
008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P2261 - 008 - Implausible Signal - Intermittent
Old 06-09-2007, 06:27 AM   #4
jheacock
Member
jheacock's Avatar
Default coil baffed?
Jeffrey Heacock
Pfaff Audi
Vaughan,ON
www.pfaffaudi.com
416.464.6987
jheacock is offline   Reply With Quote
Old 06-09-2007, 06:35 AM   #5
Ed@mtl
Ed@mtl's Avatar
Default Issue solved. Too embrassed to say what it was.
All I have to say is use a clamp instead of a tie-wrap when there's about 18-20lb psi...
Carry on...
Old 06-09-2007, 06:41 AM   #6
wellused
Default Where did you use it? DV?
wellused is offline   Reply With Quote
Old 06-09-2007, 06:44 AM   #7
Ed@mtl
Ed@mtl's Avatar
Default Yes.
Old 06-11-2007, 02:16 PM   #8
Kirk
Kirk's Avatar
Default Thank goodness for VAG-COM.
Kirk is offline   Reply With Quote
Old 06-11-2007, 03:30 PM   #9
mtlhoser
Default Ed, can you please give me some more details? ...
I'm interested in this valve (they are currently sold out). In Forge's installation instructions, I see tie wraps used for all connectors. Were you missing the tie wraps from Forge's kit? I assume that you used clamps for the vacuum tap. Did you also use a clamp for the attachment of the vacuum line to the new valve?
mtlhoser is offline   Reply With Quote
Old 06-12-2007, 05:05 PM   #10
Ed@mtl
Ed@mtl's Avatar
Default I don't remember if there were any tie-wraps but I did use them on the small lines on the actual DV
but the clamps are a must where the vacuum taps are. Also, you'll need maybe about 4" of a 10mm ID hose for the vacuum lines.
I actually hit 21psi today
Here's a link to a DIY from an Audizine member.
008801, boost, car, control, fuel, heacock, jeffrey, malfunction, measuring, mechanical, n249, p1093008, pfaff, pressure, spudding, system, valve
