#1 | ||
#2 |
Yea, though I drive in the Valley of the Shadow of the V8, I shall fear no V8 for the V6 twin turbo is with me. Thou shall prepare boost at my call against the V8 that troubles me. Thou annointest my V6 with Motul Oil and Shell 91, and my psi shall runneth over. Thy loving smoothness and torqueness shall follow me all the days of my driving and I will dwell in the house of the V6 Bi-Turbo forever. |
#3 |
So it would probably be best to go off some of the frame of the car. Old Camaro was off 3/4" from side to side on the rear fenders but sitting level from the frame.
![]() || 18" RS4 Reps || GIAC X || APR Exhaust || PureMS Testpipe || AWE DTS || Stasis Tracksports 550/650 || RS4 Motormounts || AWE Boost Guage || Momo Handbrake || RS4 Grill || + 1 Stage 3 S4 |
#4 |
The different looks and wheel gaps on both sides start getting to me.
#5 |
That is so that the car is level for alignment issues and balancing etc. If you go by the body panels the car could actually be leaning because the panels arent straight. I have a similar issue coming up when i do my coilover install, everyone seems to go by ground to middle of the fender to measure. But the problem is that fender may not be correct or straight so i am thinking of going from ground to somewhere on the subframe side to side on the front and not so sure for the back yet.
#6 |
#7 |
Member
#8 |
Member
2 options:
1. for looks (and should be decently balanced). Adjust the coilovers to as close as possible side-to-side, wait for them to settle, and lift car to adjust sides that you want to change. Mid fender to ground is an OK way to measure this, and you can compare back to front or positive or negative rake. get all the heights where you want them and it will look good! Doesn't mean car is balanced though 2. Corner balance. Adjust the corner heights while car sits on 4 scales, per corner. Once all scales display the same weights (or whatever changes from neutral you want), the car's balanced. Doesn't mean the heights will be the same at each corner though. Driver shoudl be in car for this technique IMO. You should think of this only if you track the car hardcore. Hope that helps Aman
#9 |
