Go Back   AudiWorld Forums » Regional & ACNA Discussion » Canadian Discussion
Old 01-13-2006, 07:56 PM   #1
4Bidden
Default ABS Control Module with ESP
Anybody in Canada gotten their ABS control module repaired locally? Anderson Solutions does not fix module's with ESP. Anyone know of a company in Canada that can do this? Its an 02 Audi S4 (B5) w/ESP. These are the fault codes:
Control Module Part Number: 8D0 907 389 E
Component and/or Version: ABS/ESP allrad D56
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found:
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
Stage 1 2002 S4 TIP
Upsolute Chip
710N
Darintake
Thermo Switch
Lip Spoiler
Roof Spoiler
Clear Cornered Lights
35% front/20% rear tint
4Bidden is offline   Reply With Quote
Old 01-14-2006, 02:39 AM   #2
audifirst
Default Re: ABS Control Module with ESP
You can't fix module, only replace with identical one.. but looking at your codes , doesn't look like to be your module issue,have you tried to change codes ? could be somewhere wiring issue or you need to reprogram it again to original codes, but you might require to do all the tests to make it work correctly..
Steering angle sensor is located behind the steering wheel where the wiper switch is as well..
Have you done any wiring lately ? or try to program it at all ?
audifirst is offline   Reply With Quote
Old 01-14-2006, 05:33 AM   #3
4Bidden
I have not done any reprogramming but I do hope to do that tomorrow. Hopefully that will fix the problems. Also, I think the previous owner switched steering wheels which might have caused the steering angle sensor to get thrown. I'll have to look into the wiring more closely.
Stage 1 2002 S4 TIP
Upsolute Chip
710N
Darintake
Thermo Switch
Lip Spoiler
Roof Spoiler
Old 01-14-2006, 12:38 PM   #4
audifirst
that makes sense.. if he did switched steering wheel
you need to do the adaptation.. Ross-tech website has instructions how to complete this..
Old 01-14-2006, 05:21 PM   #5
4Bidden
Thanks for your help, hopefully this will fix the problem. I'll find out tomorrow.
Stage 1 2002 S4 TIP
Upsolute Chip
710N
Darintake
Thermo Switch
Lip Spoiler
Roof Spoiler
01, 2001, a4, a6, abs, audi, code, control, esp, location, module
