#1 | ||
![]() 2007 Mini Cooper S 2007 Toyota Tacoma 2001 Sequoia Ltd.- Silver/Grey |
#2 |
Junior Member
I'm assuming that the kit you have is not self-leveling or am I wrong?
--RGL |
#3 |
much better just to park infront of your garage door and adjust it with a hex key.. takes 2 mins.
#4 |
to prevent blinding oncoming traffic. I'm glad my car's got factory xenon, if I had a S4, I would put them in anyways.
'07 GTI - Candy White 4-dr 6-sp, sunroof, 35% Tint, Clear-bra, Yellow fogs, clear side markers, open front grills, Euro light switch, Golf ball ****, Euro springs, OEM LED tails '01.5 S4 - Santorin/Onyx 6-sp, xenon/ecodes, LED tail lights, 35% tint, debadged, RS4 grill, AWE center vent boost gauge, 710N's, Stasis Tracksport c/o (500/600/sport)... Sold!! '01.5 A4 1.8tqmsx - Silver/Onyx, 35% tint, debaged, UUC SS, APR boost gauge... Sold!! '90 CQ - T-red/black 5-sp, no A/C and loud exhaust mod :-( |
#5 |
so I get this with the addition of a 5-pin relay:
Position 0: all lights off Position 1: city lights only (and rear park lights), no park front lights, no xenons Position 2: xenons and front park lights, no city lights All lights will turn on and off on command with the ignition in the "run" position. If the ignition is off, Position 2 doesn't turn on the xenons. The link below showed me how to pull the relays and add the jumper wire. I performed "Option 3" to completely disable the system. However, I'm looking into wiring a DRL circuit to switch on the high beams at a reduced voltage when the ignition is on. Currently, I have to turn on the city lights as my DRLs but they're not real DRLs, legally speaking. 5FF 01 S4 |
#6 |
but I will bet the vast majority of those who upgrade from halogen to xenon do not bother to do it. The factory self-leveling system has sensors at the front and rear suspension, motors in the headlight housings, and some smarts to tell the motors what to do. I haven't read of anyone attempting this, so the benefit must be negligible compared to the cost.
5FF 01 S4 |
#7 |
#8 |
but it trims your headlights up or down on the fly. The system moves your headlights down when you accelerate from a stop because your back end will squat. It will move them up when you brake because your front end will dive. It's supposed to detect the difference between the front and rear suspension readings to determine how to adjust the lights. If there is no difference detected, the motors return to the "home" or "level" position which is where you've set them in your driveway.
5FF 01 S4 |
#9 |
there will be no nose diving or rear-end squatting.:-)...mmmmmm maybe ill go with 1000lbs front and 1200 lbs rear...
#10 |
