Go Back   AudiWorld Forums » Regional & ACNA Discussion » Mid Atlantic Discussion
Old 09-27-2008, 10:22 PM   #1
Jimax
Default People who use rhino ramps on epoxied floors...any problems with the ramps sliding?
I discovered an interesting problem with my ramps today. I use them all the time to change oil. I changed the oil on the A4 and the M3 today (along with replacing the rear pads/rotors on my truck). A4 goes up the ramps no problem. M3 did not. The ramps kept sliding with the M3. I'd get the front wheels part of the way up, then the ramps would start sliding. I tried like 3 or 4 times, then I think I realized the problem.
On the A4, since it's AWD, the front wheels are actually driven and help pull the ramps behind the wheels. On the M3, the front wheels obviously aren't driven and between the 4000Lb plastic rhino ramp and my epoxied floors, I wasn't able to get enough traction on the ramp to get the car up.
Solution: change oil in the driveway instead. Rhino ramps over concrete > rhino ramps over epoxied floors.
Jimax is offline   Reply With Quote
Old 09-27-2008, 10:42 PM   #2
Wind-n-Water
Default clean or install rubber feet pads below rhino ramps...?
Wind-n-Water is offline   Reply With Quote
Old 09-28-2008, 01:56 AM   #3
bobster4
Member
Default Or drive only awd cars.
bobster4 is offline   Reply With Quote
Old 09-28-2008, 03:40 AM   #4
jimax bro
Member
Default Jiffy Lube to the rescue! :-)
jimax bro is offline   Reply With Quote
Old 09-28-2008, 05:23 AM   #5
arob
Default Okay, time to purchase a lift for your garage. YOU purchase, of course. ;o)
arob is offline   Reply With Quote
Old 09-28-2008, 05:57 AM   #6
jlax01
Default I had problems getting up on Rhino ramps with my car on cement...
Its easier to just jack the car up in my own opinion
-Josh
jlax01 is offline   Reply With Quote
Old 09-28-2008, 07:10 AM   #7
Jimax
Default Lazy ----->
Jacking the car up and setting jack stands requires more effort than driving up on to ramps. Me = lazy.
Old 09-28-2008, 07:13 AM   #8
Jimax
Default Let me get right on that
I'LL purchase the lift using YOUR AmEx. Haha.
Old 09-28-2008, 08:32 AM   #9
quattrothatcould
Default My friend had the same problem when he borrowed mine to change his oil on his 735il
Your reasoning makes sense
-Matt
2004 Audi A4 1.8t 6MT Quattro
"Modding is like herpes; once you get the itch, it never leaves."- OpenSkye
Dahlback | Milltek | AWE | Vogtland | H-Sport | Oettinger | BFGoodrich | Thule | OEM+ | Dents
Wish List: Stasis Torsen Center Differential, S4 Recaros (Black leather), Affordable parking in Washington DC
KMD Tuning
Stock Dyno (w/ Milltek): 162.5 HP; 164.5 ft/lbs TQ
Dahlback Stage 2 Dyno (w/ AWE FMIC, Milltek): 244.8 HP; 312.8 ft/lbs TQ
2002 Audi 1.8t K04'd Tiptronic
Gone but not forgotten
quattrothatcould is offline   Reply With Quote
Old 09-28-2008, 08:37 AM   #10
TwinTurboTerror
Default Rhino ramps are supposed to have rubber feet.
TwinTurboTerror is offline   Reply With Quote
a4, audi, cement, ramp, ramps, rhino, rhinoramps, sliding
