#1 | ||
Senior Member
Every good driver has bugs stuck to his door windows - do it sideways ;-) ![]() ![]() Visit us @www.motoring-foundation.com or the ACNA-NJ Chapter |
#2 |
#3 |
which I've found to be as useful as the allroad forum.
www.dorkiphus.net Good seeing you this past weekend. )
#4 |
#5 |
Senior Member
#6 |
Senior Member
definitely for VIR in November :-)
I guess the allroad has now officially become a towing vehicle.....she needs a break anyways :-)
#7 |
It seems that the 944T go every two years through a head gasket. This is a pricey job. Make sure the gearbox is in good shape and the clutch as well. I got mine in perfect condition except the timing belt, water pump, etc need to be replaced.
Check Dorkiphus.net and Rennlist.com for more guides for buying a 944 or 951.
2003 Audi A6 2.7T AKA "Fat Albert" w/REVO Stage 1 1986 Porsche 944 NA - Being prepared for the track.... |
#8 |
Senior Member
responded to setup a test drive so we'll see how it feels with the clutch, tranny, oil pressure etc pp....
Are there any upgrades for the head gasket available? Something like a racing version based on metal and other composites?
#9 |
Those little 4 bangers putting out a lot of power need a cooling system that is in tip top shape. This issue tends to only surface when it's being pushed on the track, so my PPI did not pick up that my car runs really hot on the track when the temp is 85+.
The head gasket on 944 Turbos does seem to go every few years. Just write it in as a maintenance cost. There will be oil leaks. You need to have someone familiar with a 944 turbo to look it over carefully, and use this as a negotiating tool with the seller. The most common areas are air oil separator o-rings, oil cooler area (very close to the oil filter), balance shaft seals. Also, like any old car, there is a possibility of steering rack leaks. Good luck. You really need a good Porsche shop that is familiar with 944s to give it a good looking over. Get to know that shop, because you're going to be spending a lot of money there! Jim
#10 |
all depends on how much a HG job is I guess :-P
-Justin Click de sig for more pix ![]() A4: LOTS 'o extras 4000S: MC1, NF head, 34mm exhaust valves, 2871 turbo, 034 Ib ECU, VAP CCK, pro-mounts, and some stiff azz springs! B5 Faq |
| Tags |
| 944, buying, check, cone, filter, ppi, turbo, wwwmotoringfoundationcom |
