Go Back   AudiWorld Forums » Regional & ACNA Discussion » Mid Atlantic Discussion
Old 10-09-2004, 08:22 PM   #1
matt13
Default My dyno graph from the Induktion Dyno Day (146whp, 171ft-lbs)
Here's all the car's info:
-1999.5 1.8TQM
-1 bar GIAC Chip (program PGL30L7.03A, which is apparently a 91 octane program)
-DIY Cold-Air intake
-50-50 Mix of 93 octane pump and VP Racing 103 octane race gas (98 octane for the mathematically challenged)
-NGK BKR5E plugs (one step hotter than normal)
The graph is of two back-to-back runs. Nothing was changed in between them, the lower numbers from the second run are due to (massive) heatsoak.
matt13 is offline   Reply With Quote
Old 10-09-2004, 08:51 PM   #2
Blake(w/ 16g)
Elder Member
Default you think induktion would dyno my scooby? :-D
/Sig\
Mid Atlantic Resident Ricer
AWOT Subaru Crew #3
Project WRX status: Output Focus
EVO III 16G installed
Blake(w/ 16g) is offline   Reply With Quote
Old 10-09-2004, 08:57 PM   #3
matt13
Default The dyno was at Extreme Motorsports, actually.
http://www.extrememotorsports.com/dyno.htm
But I'm sure they'd be more than happy to dyno it.
Old 10-09-2004, 09:01 PM   #4
Angry Alex
Default Why are you running hotter plugs?
As far as you're concerned I'm daddy.
Angry Alex is offline   Reply With Quote
Old 10-09-2004, 09:08 PM   #5
matt13
Default I asked on the performance forum and Audi2ptzero said I might want to try 1 step hotter
with the higher octane gas. I'm guessing because the higher the octane the harder it is to burn. Either way, I changed the plugs right after the dyno because they are too hot to run all the time on pump gas without fear of detonation.
Old 10-09-2004, 09:20 PM   #6
Gldnrkt(GT3076R)
Senior Member
Default 26 whp gain over stock?? (is teh 99.5 150 or 170 hp??)
B5 FORUM FAQ, for regulars and n00bs alike!
NIGHT->(KTacks952@hotmail.com)
DAY--->(steve.g@aefcu.com)
AIM-GldnRktStg3
Gldnrkt(GT3076R) is offline   Reply With Quote
Old 10-09-2004, 09:22 PM   #7
Durrrrty Dufour
Member
Default um, 150, the only one that is 170 is the 01
Disclaimer: chances are something in my post will be spelled wrong, since I am teh suck at teh spelling (and grammar/punctuation). Please refrain from pointing these mistakes out to me as I will not learn from my mistakes.
When I want your opinion, I'll give it to you
AIM: dufsB5turbo
High end road bike parts FS
Check out:
Induktion Motorsports
great shop
Durrrrty Dufour is offline   Reply With Quote
Old 10-10-2004, 08:05 AM   #8
Audi2ptzero
Elder Member
Default If the chip is for 91 octane why would you put fuel to get 98 octane?
YOu were better off just running straight 93 octane. As you can see the AFR's are way too rich and that is killing the power. Bad thing is that if those are measured at the tail pipe your AFR is even richer then what the graph says. You might want to go back and run again with just 93 octane in the car or see about getting a 93 octane chip.
Audi2ptzero is offline   Reply With Quote
Old 10-10-2004, 08:49 AM   #9
matt13
Default I'll keep that in mind if there's a next time.
Yes, A/F was measured at the tailpipe. The race gas was actually oxygenated, too.
146whp, car, giac, hp, pgl30l703a
