Engine flush before and after pics......
Old 12-04-2008, 04:57 PM
Sal@elitemotorsports's Avatar
Default Engine flush before and after pics......
as per the Audi TSB using the BG Dynamic Engine Flush.
<img src="http://pictureposter.audiworld.com/19535/dscn2697.jpg"> <img src="http://pictureposter.audiworld.com/19535/dscn2698.jpg"> <img src="http://pictureposter.audiworld.com/19535/dscn2699.jpg"> <img src="http://pictureposter.audiworld.com/19535/dscn2710.jpg"> <img src="http://pictureposter.audiworld.com/19535/dscn2711.jpg"> <img src="http://pictureposter.audiworld.com/19535/dscn2712.jpg"> <img src="http://pictureposter.audiworld.com/19535/dscn2713.jpg">
Old 12-04-2008, 08:21 PM
Banned
AudiSpaulding's Avatar
Default seafoam is the shiv, just don't use it too much (like every other oil change is good)
because it's solvent based and the rubber seals don't like it too much
Old 12-04-2008, 08:44 PM
ruknd's Avatar
That's why I heard it's a bad idea.
Old 12-04-2008, 08:48 PM
Banned
Default it's great for periodic use, like I said. I don't recommend using it through the intake
in broad daylight though, it can create quite a smokescreen from all the stuff it's cleaned out
Old 12-04-2008, 08:54 PM
Audi Junkie's Avatar
Default WOW, awesome result.
fwiw, I'd still run some Auto-Rx thru it.
A pristine example for comparison....
<a href="http://s15.photobucket.com/albums/a364/AudiJunkie/bitog/?action=view&current=1.8tVC.jpg" target="_blank"><img src="http://i15.photobucket.com/albums/a364/AudiJunkie/bitog/1.8tVC.jpg" border="0" alt="Photobucket"></a>
Old 12-05-2008, 03:59 AM
02 Silver Arrow's Avatar
what type of oil had you been using prior to the flush?
Old 12-05-2008, 04:47 AM
KillA6's Avatar
Mine was not that bad at all. I did it twice and yea it smoked but not crazy like some people say.
Old 12-05-2008, 05:02 AM
Banned
Default I took it around the block, and into 280 for a mile and full throttle, smoked 90% of the way
I could barely see out my rear window
Old 12-05-2008, 06:00 AM
919B6's Avatar
Default so where does all the crud go?
does it really break it up enough that it gets into the oil filter?
Old 12-05-2008, 07:05 AM
Member
chris w/ a b5 1.8t's Avatar
Default ouch. nasty sludge build up. your car? how did you clean it?
just multiple seafoam flushes or did you break out the toothbrush?
Definitely a good cleanup job.
Quick Reply: Engine flush before and after pics......
