Go Back   AudiWorld Forums » Regional & ACNA Discussion » Texas Discussion
Old 02-08-2005, 01:16 PM   #1
TTransport
TTransport's Avatar
Default Zimmerman Rotor Fun
After 8 days on the car two of which were at MSR... FasTTr let me have his old ECS drilled and slotted or I would have had a long walk back to Austin
MyFotki: Lots of Pics
<u>2001 Audi TTQRoadster RavenBlack 2.2L-&gt;BT: </u>
Motor: 2.2 forged Crank/Rods/Pistons, Girdle &amp; deck cooling, Custom QEDpower Head with Schrick cams and Cat springs
Forced Induction: GT3071R-WG-86AR-90TrimTurbine, DelRio Race Intercooler, DelRio BT Piping, Evo VFlo+ B5 S4 MAF, APR Bigport Intake ceramic coated, R32ThrottleBody, CoolingMist WaterMeth, larger injectors, fuelpump, etc
DP-Exhaust: FastIntentions Custom 3”DP and Cat / test pipe section, BlackSheep Custom 3” cat back section with magnaflow resonator
Suspension: VF Eng Mounts, KWV3+upratedfrontsprings, GroundControl C&amp;C Plates, SpericalBushings ControlArm+Defcons+Poly, RearCamberBars, Uprated SwayBars
Brakes: StoptechBBK 355 x 32 mm
DriveLine: HaldexBlue + PeloquinRearLSD, SouthBendK70287FE
Misc: Zeitronix EGT/WBAFR/Boost, Oil Temp/Pressure, Setrab oil cooler and oil filter relo, adjustable FPR/fuel pressure gauge
Cosmetics: OSIR Fenders, SGI Carbon rear, 5PointHarness, race seat, custom front splitter, Black UFO, Black PC ValveCover, clear corners
TTransport is offline   Reply With Quote
Old 02-08-2005, 01:43 PM   #2
AWES4
Default I doubt braking force had a part in the sheering of ......
the hat from the rotor it self. It seems something has to have been warped, or mis aligned when you tightened it down. I'm not saying you're at fault, It's just something to consider. Maybe check out all the mechanical parts on that hub before you break another one, if something is indeed bent or broken.
AWES4 is offline   Reply With Quote
Old 02-08-2005, 02:04 PM   #3
TTransport
TTransport's Avatar
Default Re: Torque wrench test etc,
I utilized my torque wrench and followed my normal alternating pattern, and up until eight days ago those hubs were fine with my factory rotors. I'm leaning toward just a plain defective rotor. I am guessing that if the rotor had never been subjected to the rigors (heat) of the track that it would have held up.
Good sugestion though, I'll have a second set with me next time in case it is the hub...
Old 02-08-2005, 06:26 PM   #4
Mike Staley
Member
Send a message via AIM to Mike Staley
Default I think you are correct... must be a defective rotor
BARTUNING.COM
Mike Staley is offline   Reply With Quote
defective, rotor, zimmermann
