#1 | ||
#2 |
Tech Guru
![]() Join Date: Oct 2002
4Driver4 "Never give up the throttle until the bitter end." -RC 2005 A6 Sedan Q 3.2 (wife's whip) 2000 A4 Avant Q 2.8 (daily driver) 2003 Mini Cooper S (Fun!) 1995 Mazda Miata: the anti-Audi 1999 Mazda Miata SSB: track beotch 2003 GMC Yukon Denali XL: the anti-earth 2004 Dodge Dakota: hey, at least it's stick and 4x4 |
#3 |
that's part of the problem. i can't do the brakes myself cuz i don't have the space or tools to do so.
#4 |
this was a while ago, so numbers are a bit off, but you can 'google' all of them for contact info
I drive a Green A6 that drinks gasoline like it's coffee.
#5 |
awesome.
thanks jimmy |
#6 |
Aftermarket friendly, rates are better, and dont have attitudes just extremely busy!
#7 |
#8 |
can run anywhere from under $10 - $50 each wheel/tire. I hear BJs or Costco is quite under priced for mount and balance.
Brakes can be done by yourself with simple hand tools really. Just need to rent the caliper tool from Autozone and return when you're done, free. Not much space is needed either. Rotors all the way around would probably be about $200 IIRC and about the same for pads (depends on what pads you get). Spend about $400 on parts for the brakes. I dunno about rotors at 35k...unless this is your second set of pads already all the way around. Generally, a rotor lasts 2 sets of pads. But I've heard bad things about Brookline of Audi, maybe they're just trying to make a quick buck off of you.
2013 Q5 2.0T Ibis | Chestnut || Prem+ | MMI Nav | B&O | Keyless 2011 A4 2.0T Quattro AT8 Quartz | Black || Prem+ | Titanium | NAV Mods: APR Stg 1 | 034 turbo hose | Huper Optik | Blinder M25 | Escort 9500xi 1995 90 Quattro Sport 5-speed Past: 2007 A7 2.0T 2006 S4 25quattro 2005 1.8T Quattro 6-speed |
#9 |
FS B5 UCC Rob Knob 1998.5 A4 1.8t Quattro/Manual (Big Turbo) 1998.5 A4 2.8 Avant Quattro/Manual (DD) 2006 Nissan Frontier 4x4 / 6 Sp Manual ![]() ![]() EPL Tuned || Dyno || Engine Pics || A4 CAPS || Turbo Setup |
#10 |
at 97k right now. I think they're trying to pull a quick one over him unless he does a lot of braking. I could see the pad wear but not rotor(s).
| Tags |
| 18t, central, garage, service |
