Go Back   AudiWorld Forums » Regional & ACNA Discussion » New England Discussion
Old 12-27-2005, 11:52 AM   #1
DJJAZZYJOE
Default ****.....???
so ...lost control and hit a curb today ....back left wheel.....TOAST.....steering wheel points alittle bit to the left now....anyone wanna be nice enough and tell me that the bent wheel is causeing this and not the ....ahem.....bent frame......
i love you guys......
DJJAZZYJOE is offline   Reply With Quote
Old 12-27-2005, 12:00 PM   #2
2000_Audi_S
Default JOE!!! how the hell did you loose control???
Anyways.. you probably just need an alignment, and hopefully nothing else. How bad is the rim? i wanna see it! but that SUCKS!
2000_Audi_S is offline   Reply With Quote
Old 12-27-2005, 12:44 PM   #3
Urban Rally
Default just a little bit of the rain freezing on the road?
I had something similar last night, everywhere it was just wet, then hit this little patch on a corner, stopped turning for that little bit, but I had enough room, that I only went over the line, and was able to safely return to my lane.
Santorin 1999.5 Audi A4q Tip 30v - Traded for a
2006 Subaru WRX TR.
Urban Rally is offline   Reply With Quote
Old 12-27-2005, 05:59 PM   #4
DJJAZZYJOE
Default Re: JOE!!! how the hell did you loose control???
hmm lets see the rim is toast......and i doubt i just need an alignment...i think most of the rear susp on that side is bent wich blows......
j
Old 12-27-2005, 07:48 PM   #5
4Driver4
Tech Guru
4Driver4's Avatar
Default Could be worse.
Sounds like you bent some rear suspension parts. That's enough to change the rear alignment enough to cause the change in steering wheel position.
4Driver4
"Never give up the throttle until the bitter end." -RC
2003 Mini Cooper S (Fun!)
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata SSB: track beotch
2003 GMC Yukon Denali XL: the anti-earth
2004 Dodge Dakota: hey, at least it's stick and 4x4
Old 12-28-2005, 04:59 AM   #6
DJJAZZYJOE
Default Re: Could be worse.
i really hope so ......
Old 12-28-2005, 07:18 AM   #7
Christian (Stage Ow)
Default You might just need an alignment. Park the car with the front wheels straight . . .
see if the steering wheel is cocked, or straight. Does it only go out of position when you're moving?
How hard did you hit the curb?
On the plus side, the rear suspension bits are cheaper, iirc.
__________
"It's easier to practice medicine without a license in this country than it is to get info on tuning Motronic." -JasonS9
Christian (Stage Ow) is offline   Reply With Quote
Old 12-28-2005, 08:17 PM   #8
DJJAZZYJOE
Default Re: You might just need an alignment. Park the car with the front wheels straight . . .
how hard.........pretty hard....and what should that test show me????
