Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B6 Platform) Discussion
Old 08-26-2008, 10:28 AM   #1
made2last
Account #: 116857
Default 5 brake questions (rear rotor size 2002 A4 B6, flush vs bleed, ABS cycling, oem fluid, slide pins)
1 - What is the stock rear rotor size for 2002 A4 B6 1.8TQ 5speed. I tried measuring last night but to get a better measurement I think I need to remove the wheel 245mm & 255mm are the choices here. I wanted to order this today
2 - Flush vs Bleed -- for flushing do I just keep feeling the reservoir with new fluid and use the power bleeder until new fluid comes out of the bleeder tube? then move to the next wheel?
3 - If am flushing the system with a different fluid, do I have to cycle the ABS?
4 - if yes on 3, I dont have a vag com so I wont be able to cycle the ABS, what is the stock fluid for the 2002 A4 B6 1.8TQ 5speed.
5 - grooving in the slide pins -- is this most likely a problem at 55k miles , should I already have 2 handy?
Thanks (from a noob in cars, who learned everything so far from this forum)
made2last is offline   Reply With Quote
Old 08-26-2008, 10:52 AM   #2
Matt Devo
Account #: 52813
Default a few answers:
1) should be 245mm, but best to check existing rotor to be sure
2) yes. best to remove old fluid from reservoir (turkey baster) first. power bleeder will keep reservoir filled for you
3) best to do so, but not the end of the world if you don't
4) see above
5) I haven't replaced mine in 125k. Just clean/re-lube
2002 A4 1.8T 5M. 130k miles and counting
AIM/Gamertag: denimA4turbo
Matt Devo is offline   Reply With Quote
Old 08-26-2008, 12:02 PM   #3
MikTip
AudiWorld Expert
Account #: 6607
Default 1.8T=245mm, 3.0L=255mm...
2004 A4 1.8t USP Quattro 6MT
K04-15/APR/TT 225 Injectors/Custom Stainless Exhaust/710N/RaceTec FMIC
034 HFC/Jet-Hot Cermi-coated & ported exhaust manifold
Spec Stage 3+ with OE DMFW!
Neuspeed TIP/Neuspeed Snub/Optima 75-35/AFE Pro-Dry/FSI Coils
AMS Short-shift @ %40 redux(Sweet!)
Bilstein Sport with H&R/ H-Sport Anti-Sway bars/E-codes
19x8.5 OEM Audi Skinny Fives with 235-35 Bridgestone 760 Sport Skins
B7 A4 brakes with StopTech Ceramic pads and Stop Tech rotors
Sirius Satellite Radio
Ross-Tech HEX-USB+CAN Equipped
Escort 9500ix
MikTip is offline   Reply With Quote
Old 08-26-2008, 12:07 PM   #4
Matt Devo
Account #: 52813
Default with some exceptions on later 1.8Ts, no?
Old 08-26-2008, 12:22 PM   #5
nanotech
Account #: 14421
Default My 04.5 has 245mm rotors
It's very few cars with the 255mm rears, I bet they just ran out of parts at the factory for the last few builds
MikeD
2004 A4 1.8TQM Ultra - GIAC FXK04
DSMIC | Southbend OFE SS | APR Stealth | B6S4 brakes | Neuspeed SS | RS4 sway | APR snub | APR TIP(removed, in garbage) | podi
nanotech is offline   Reply With Quote
Old 08-26-2008, 01:36 PM   #6
made2last
Account #: 116857
Default thanks guys!!
Old 08-26-2008, 01:49 PM   #7
Bronze
Senior Member
Account #: 61481
Default I thought it was very early 1.8Ts with the exceptions.
Bronze
2002 A4 1.8T M/T quattro
Brilliant Black/Ebony
APR Stage 1, snub, TIP, 710N DV
Neuspeed Short Shifter
Koni FSD/Eibach/H-sport S4 sways
B5 S4 front brakes, Porterfield R4S
Stoptech SS lines
Dunlop SP Sport 01/Yokohama AVID H4S
Bronze is offline   Reply With Quote
Old 08-26-2008, 02:38 PM   #8
quattrothatcould
Account #: 105649
Default Yes
Some late '04's and '05's had the 255mm rear rotors, but there was no rhyme or reason to which cars had them
-Matt
2004 Audi A4 1.8t 6MT Quattro
"Modding is like herpes; once you get the itch, it never leaves."- OpenSkye
Dahlback | Milltek | AWE | Vogtland | H-Sport | Oettinger | BFGoodrich | Thule | OEM+ | Dents
Wish List: Stasis Torsen Center Differential, S4 Recaros (Black leather), Affordable parking in Washington DC
KMD Tuning
Stock Dyno (w/ Milltek): 162.5 HP; 164.5 ft/lbs TQ
Dahlback Stage 2 Dyno (w/ AWE FMIC, Milltek): 244.8 HP; 312.8 ft/lbs TQ
2002 Audi 1.8t K04'd Tiptronic
Gone but not forgotten
quattrothatcould is offline   Reply With Quote
18, 18t, 2002, a4, audi, b6, brake, bronze, flush, oem, rear, rotor, size, tiptronic, wheels
Forum Jump
