Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B6 Platform) Discussion
Old 05-31-2006, 10:22 PM   #1
wxpaul
Default about the stereo in A4 B6
in my A41.8T B6 it equipped with an Audi Chorus...
which stereo is better? is the concent > symphony > chorus?
can i upgrade to RNS-E from this chorus? it seems i have to remove the chorus & move aircondition panel down to launch the RNS-E.
wxpaul is offline   Reply With Quote
Old 05-31-2006, 11:03 PM   #2
MB The Body
AudiWorld Uber User
Default I don't think I've ever seen a single din radio before on a b6....
I'm wondering if you went Nav+ if you could simply put the AC down below or if there is more to it.
MB The Body is offline   Reply With Quote
Old 05-31-2006, 11:49 PM   #4
MRSK
Default A single DIN unit stares at me everyday (cos I have one in my car too)
2003 Audi A4 1.8T
BBS 19" CH wheels, Falken FK451 245/35ZR19, OEM Sports Suspension, Votex Body Kit, OEM S4 Front Grille, Kersher Carbon Fiber Front Lip, Remus Sport Mufflers, ECodes, 6000K Xenon Kit, Debadged, Moro Blue
MRSK is offline   Reply With Quote
Old 06-01-2006, 12:23 AM   #5
wxpaul
Default is this new AC control unit for supporting RNS-E?
tks for comments
does this mean the AC panel (originally matched 1DIN stereo) will need another bracket to support the double DIN RNS-E?
i got another ebay seller for this item 8E0858005 F, & i suppose this might be the right bracket required for upgrading job.
Old 06-01-2006, 05:04 AM   #6
PDXA4
PDXA4's Avatar
Default Standard fair in Europe
original PDXA4
2003 D2 S8
2008 mkV GTi
2006 NC MX-5
former:
2003 A4 Avant
2000 A4 several mods
PDXA4 is offline   Reply With Quote
Old 06-01-2006, 05:25 AM   #7
AudiA4B6US
2012 Audi A6
AudiA4B6US's Avatar
Default Symphony > Concert > Chorus
Concert (with single CD Player) and Chorus (with compact cassette) are the single DIN units, Symphony is a double DIN unit like the RNS-E. In the B6 all radios are 2nd generation using CAN to talk to the car, so what you have is a Chorus II.
Electrically the radios all use the same connectors, usual differences are with/without Bose, with/without external CD changer and with/without phone.
To retrofit a double DIN unit you will need a new radio cage and modify (dremel) the A/C unit to fit further down in the center console. You could also get a double DIN A/C unit (get one with/without heated seat to match what you have right now) and move the electronics from your A/C unit over to the new A/C unit. If you want to get it perfect you will also new a new ashtray.
This guide should give you an idea on what's required to get an RNS-E installed:
Installing RNS-E SAT NAV for Audi A4
2012 A6 3.0T Prestige, Aviator Blue, Innovation, 18" Sport, Cold Weather, Black Headliner, 20" S6 Wheels
2005 VW Jetta GL 2.0, Galactic Blue
2004 A4 3.0 Avant Ultra Sport, Moro Blue, Premium, Infotainment, Cold Weather, 2010 RNS-E with AMI and Tune2Air Bluetooth, Dice and Sirius
AudiA4B6US is offline   Reply With Quote
Old 06-01-2006, 08:06 AM   #8
bla4ck
Senior Member
Default is that an 8-track player?
bla4ck is offline   Reply With Quote
Old 06-01-2006, 10:35 AM   #9
a4tis™[Bye Turbo]
Senior Member
Default its the optional factory in-dash betamax player
2000 S4 6-spd (MTM Stg I)
MTM ECU
APR Bipipe
710Ns
RS4 MM
APR Snub
ASP DTS
Stasis Street Sports
'Darintake' Airbox Mod
VAST short shifter
Clear Corner Mod
How to fix your randomly opening sunroof
THE B5 S4 FAQ
How to install a boost gauge
a4tis™[Bye Turbo] is offline   Reply With Quote
Old 06-01-2006, 03:46 PM   #10
Alister
Default I went from Chorus to RNS-E - You'll Need All This
Some people cut down their existing climate control (the console tapers in a little at the bottom) - I just replaced it with a new double din climate control..
You will need the double din chassis/cage to mount the equipment (you can see it at the back of my photo).
Alister is online now   Reply With Quote
18, a4, audi, b6, b7, cage, connectors, din, double, install, modify, retrofit, single, stereo, symphony
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
