gear indicator display flashing
Old 12-29-2004, 12:10 PM
amiyar's Avatar
Default gear indicator display flashing
i have a 2004 1.8t, with about 7000 miles on it.
driving today as usual, not experiencing any problems, and i noticed that the Gear indicator display was flashing - not each letter - the entire thing, P R N D S...
The background would alternate red and black and the letters change, too.
Anyone have any idea what this is indicating? There aren't any other indicator lights on and the system check is normal.
Appreciate any help.
Old 12-29-2004, 12:30 PM
quattroED's Avatar
Default I had something similar, except mine stayed lit up for a while....
never found out what the problem was. It went away after about an hour.
Old 12-29-2004, 04:27 PM
Senior Member
J.Moss@TorqueFactory's Avatar
Check the TCM for faults.
Old 10-06-2010, 05:46 AM
akgathego's Avatar
I had the same problem sometimes it will go away,the following code came from a scan
17137 17137.P0753 Shift solenoid A-N88:electrical
17134 17134.P0750 Shift solenoid A-N88:malfunction
it means the gear are not shifting,try to accelerate and look at the rev counter and if you can hear the gear shifts if you accelerate.
these can be fixed
(i)thorough flushing of gearbox oil
(ii)checking the + (red) terminal of your battery(do u see any acid leaks)--Change the battery as a bad battery can cause the solenoid to fail
(iii)check the wiring(insecure wiring can cause that)
(iv)Finally solenoid replacement
The car will still move but is not shifting gears
hope it helps
Michellehmcclure (02-16-2020)
Old 10-07-2010, 10:28 PM
s4master1's Avatar
Default light flashing
most likely you drove in a place with water and it splashed on the range control switch connector under the car, it probably will happen again check the connector and make sure is insulated is under the car on the left front side of the transmission
davidbod
Q7 MK 1 Discussion
36
07-25-2022 07:57 PM
beachcomber
14
07-26-2021 05:08 AM
ake11
07-04-2016 09:51 AM
levansula
12-10-2015 04:10 PM
PaulNZallroad
Audi allroad
09-17-2015 04:46 AM
Quick Reply: gear indicator display flashing
