Wiring through firewall?
Old 01-05-2004, 10:00 AM
Avantadrive_Original's Avatar
Default Wiring through firewall?
I need to get a wire, heavy guage, through from the engine compartment into the area behind the glovebox. Any ideas on how to do so? Is there a grommett i can take advantage of?
Old 01-05-2004, 10:30 AM
eh-4Q1.8's Avatar
Default I used the ECU box on the drivers side of the engince compartment. go to the APR website for (m)
directions for removing the ECU cover.
Old 01-05-2004, 12:32 PM
TH3_FRB's Avatar
Default There are several unused holes with rubber grommets already waiting...
Roughly under the steering column. I had a bank of about 6 together with rubber grommets/plugs. I just took a metal coat hanger with a nice point on it and poked it through from the inside...then duct-taped the end of my 4ga to it from the engine side and pulld it back through. Need a little dish soap for lube
Old 01-05-2004, 10:54 PM
bootnet's Avatar
Default do not go through firewall.. there is a better way <more>
If you dismantle the drivers side under part of the dash (3 bolts) then you will find a power distribution center with 6 ports.
This power dist center comes straight from the battery using heavy guage wire..depending on your options some of the ports will be full but its a great place to tap in for power for amps or whatever..its capable of feeding 8guage cables etc.
It makes it perfect cuz you never have to drill through the firewall or mess up sealing grommets that come through the firewall.
Old 01-06-2004, 06:56 AM
thanks, but the wire is for an antenna
Old 01-06-2004, 07:14 AM
bootnet's Avatar
I see,, ok yeah I understand now.. good luck !
Old 01-06-2004, 08:26 AM
eh-4Q1.8's Avatar
Forgot to say that there is loads of room thru the firewall via the ECU box.
Old 01-06-2004, 08:55 AM
Default yeah i know, (more)
i've used that already for sending some wires down from the battery. however, i hate having to remove the ecu box (wipers, etc.) because its a pain, not to mention the antenna wire is much thicker than the hole i've drilled into the ECU box already. additionally, the wire will be passing into the area behind the glove box, so it seems silly to route it all the way to the other side of the car and back. i'll let you know if i find another way!
fmladineo
Q7 MK 1 Discussion
9
05-03-2022 10:55 PM
S6Express
A6 (C7 Platform) Discussion
01-29-2022 04:31 AM
anordin2
02-08-2017 11:07 AM
A6_4.2_V8
10-25-2015 11:37 PM
N_Jay
09-25-2015 08:00 AM
Quick Reply: Wiring through firewall?
