| Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride |
#1 | ||
![]() 2001.5 M-Box MTM Stage 1 T-Box Code 710N/Samco TBB Neuspeed Catback H&R Streets 18" RS4s Falken Azenis CC-Mod RS4 Grill After-Run Thermoswitch SPP/Autometer Carbon Fiber Boost Gauge |
#2 |
I have pretty much the same setup you are buying. You will not regret your purchase. The results are amazing.
![]() MODS/UPGRADES: 17x8" BBS RKs (great AW story about how I got them...) | H-sport anti-sway bars | ToyGuy short shifter | IceLink/iPod integration | Escort 8500 hardwire | fog/running light rewire | HomeLink home lighting control | fold-down bag hooks in the trunk | aux power socket under the armrest | hidden Symphony EQ settings | remote locking control recode | debadged SUGGESTED READING FOR C5 A6 OWNERS: 2001 A6 info from AudiWorld | 2001 A6 info from Edmunds.com | Audi 2001 maintenance schedule | Stoney's links (the ultimate A6 links page) | the nOOb's guide to everything | how to make your car shine The other ride: 1998 Mitsubishi Montero (typically with a kayak on top) |
#3 |
For the matte black rubber and plastic trim (door trim, front grille, etc.) of my A4, I use 303 Aerospace Protectant. For the glossy black trim on the B-pillar, etc., I'm not quite sure what to use.
By the way, if this helps you, I also ordered the Menzerna kit from Proper Auto Care and was pleased with both the service and the products. I'm not convinced that the soap/shampoo is worth the premium, but the glazes and sealants are top notch, very durable and great shine. If you don't already have some, I'd recommend getting Proper Auto Care's waffle-weave drying towels, as they really do work as advertised. (I'd get the large towel-small towel combo, and use the smaller towel for drying the lower parts of the car, which are most prone to collecting grease and grime. I also use a seperate mitt for washing the lower bits for the same reason.) |
#4 |
Junior Member
I would stick to the orange pad. Easier to use and follow up from than the yellow pad. You can get yourself into trouble with misuse of the yellow one. You should consider a quickdetailer like Meguiars Final Inspection (#34)to finish up your detail and also you can use it to prime your pads for the machine.
303 is also very very good. I use it for tires and most rubber and plastic. It does not wipe clean as easily from glass or paint as does Black Again. And Black Again lasts longer than the 303 on certain applications. Other tire dressing I have found sling product onto fenders more than the 303 with the identical application process. You should also get the larger waffle weave drying towel as mentioned before. I use two. One for dirty areas like door, trunk, and hood jambs and the other for the vehicles finish itself. Do you have the little spray bottles for your 50/50 solution of alcohol and water? Also do you have an assortment of brushes for exterior and interior? Micro fiber towels? Best bang for the buck in good quality towels are the towels from Rightlook.com. Get a small set with three colors. Yellow for interior, blue for glass, and green for exteriors and misc work. Keep them seperated, wash them seperately, dry them seperately. You dont want them to collect debris from the floor or anything like that. They act like magnets. So be cautious how you treat them because you will be rubbing them all over your paint. There is soo much more you can get. its all about what you cant do without to do the job as best you can for the $$$. Good luck and have fun...
#5 |
#6 |
1. get both the yellow and the orange pad, different "cutting" / polishing properties. even if you do not need the yellow pad right now, it's always good to have it, just in case.
2. ERV for exterior 3. 303 for interior 4. you may also want to add the following to your cart, wtf, it's only money: clay bar, waffle weave drying towel, extra microfiber towels, mf application pads, car wash shampoo and detail spray. 5. also, pick up a few bins to store all this stuff in
![]() Long Island, New York |
