| Auto Detailing Discussion Discussion forum for the in's and out's of properly detailing your ride |
#1 | ||
Junior Member
#2 |
Junior Member
P21S GEPC = S100 GEPC
It's the same thing, and the S100 costs less. (Can be bought at a Harley Davidson shop...it's use for motorcycles) (it won't be a lot less, but it may save you a few bucks) Also, when you apply the P21S, make sure you apply it AFTER the Menzerna FPII, but BEFORE the Blitz wax
#3 |
Junior Member
#4 |
Junior Member
the p21s actually stays on the car (with oils and stuff) which help FILL IN the swirl marks. The P21s is more of a cosmetic filler (which will get removed over time) while the final polish 2 actually removes some clear coat to remove swirls/scratches
#5 |
get some Menzerna Intensive Polish as well or other comparable polish with slightly more agressiveness than FP II.
IMHO it's better to get rid of swirls than cover it with fillers.
98 A6 2.8 Quattro Honolulu, Hawaii |
#6 |
Junior Member
better to start with something not too aggressive
#7 |
Junior Member
#8 |
Junior Member
do more harm than good over time. He tends to talk out of his *** sometimes though. Is there any truth to it?
#9 |
work up in aggressiveness ONLY IF NEEDED.
As common sense will tell you, you can't put paint back once you've taken it off so start mild and check your results. Not knowing the condition of your paint and knowing that a bottle of Menzerna Intensive Polish is only going to run you $16 I merely suggested it so as to not have you waste time trying to push FP II beyond it's capabilities should more agressiveness be required for your car. FP II certainly can handle micromarring and some light swirls but if you've got anything that needs more you may find yourself working on each panel much longer than you would with something stronger. As far as the "over time" thing, generally speaking yes if you continually polish with agressive polishes you're going to do damage. HOWEVER, the key to eliminating this risk is to not only follow the rule of thumb of starting mild but also to reduce the need to polish to begin with. Swirls and micromarring on your finish are produced by the processes that you use to clean the car. Scratching can occur either due to the products you use like towels and mits or the way you wash it (search for talk of multiple bucket techniques using wash mits). Fix that and add a good sealant and the frequency of polishing goes down dramatically. Bottom line; if you've got a car that hasn't been heavily polished before and you need to tackle swirls then chances are you won't be in trouble going from mild to more agressive once and then fixing your care/maintenance process to minimize swirls from that point on. Owners of black cars can testify to this for sure . .
#10 |
Junior Member
