Old 03-29-2005, 08:42 AM   #1
quattro_silver
Default [cleaning wheel dirt]- I have dirt really caked on my SL's..any tricks/products I should try?
I have only been using soap/water, since I don't want to damage any of the finish. I don't want to use anything abrasive, but I have dirt/grime/brake dust that seems to be caked in certain areas. Is there any trick, or product that will breakup the dirt better than soap, that won't damage my rims?
-btw, the wheels are off the car.
b5 s4
apr 93
black o.z ultraleggera 18x8
neuspeed g2 exhaust
piggies
kuhmo mx
phatbox
podi boost gauge
quattro_silver is offline   Reply With Quote
Old 03-29-2005, 09:04 AM   #2
GDA4
Junior Member
Default Eimann Fabrik Hi-Intensity cleaner works great
2006 330xi - Active
1999.5 A4 1.8T Quattro - Sold
1996 VW Passat GLX - Sold
1986 Audi 5000S - Retired
GDA4 is offline   Reply With Quote
Old 03-29-2005, 09:09 AM   #3
Reg Dunlop
Default P21S Wheel Cleaner is an excellent wheel cleaning product
Just spray it on (gel version is stronger than the liquid), let it sit for a while, and then agitate with a soft brush (foam or boar's hair). It hasn't failed me.
You may then need to clay the wheels to get them fully clean, depending on how long have remained dirty.
As has been discussed before on this board, whatever you use, make certain to avoid acidic wheel cleaners. They can damage your wheels' clearcoat if let to sit for too long.
Good luck.
- JT
Former: 1995 90CSQ, 2002 S4 Sedan, 2004 S4 Avant
Current: 2006 Toyota Tacoma Doublecab TRD
Reg Dunlop is offline   Reply With Quote
Old 03-29-2005, 09:55 AM   #4
quattro_silver
Default I have the Zymol wheel cleaner, how would that compare?
I am hearing good things about the p21S gel, maybe I'll try that. I have this Zymol left though. It comes with a brush to clean the hard-to-reach spots, but I think I might try something else. I have cleaned these wheels before with the Zymol, but this time I think I am going to use a cloth with soap/water first.
b5 s4
apr 93
neuspeed g2 exhaust
piggies
kuhmo mx
phatbox
podi boost gauge
Old 03-29-2005, 10:54 AM   #5
Reg Dunlop
Default Hmmm. I can't really help. I've never tried the Zymol before.
For what its worth, the P21S stuff has always worked for me. And, it happens to be on sale at CCS.
- JT
Old 03-29-2005, 11:04 AM   #6
quattro_silver
Default I just cleaned 1 rim.. it's little tar spots that I need to remove, what is good for tar?
b5 s4
apr 93
neuspeed g2 exhaust
piggies
kuhmo mx
phatbox
podi boost gauge
Old 03-29-2005, 01:07 PM   #7
Reg Dunlop
Default Two different approaches available
If the spots are indeed small, I'd use a clay bar. It will take off the tar spots and will at the same time remove all other deposition that has bonded to your clearcoat. Claying your wheels is the best way (I think) to bring them back to looking near-new.
Another option would be to go the route of a solvent or chemical to remove the tar. This might be a better approach if you have a considerable amount of tar on the wheels (clay is less effective then because it will get contaminated quickly). If you were to choose this route, in my opinion the best product is 1Z Anti-Insekt.
I'd guess claying is the best approach. If you're a clay bar veteran, you know whats involved. If you're a claying noob, don't worry, its a REALLY easy concept to learn. Just cut off a smallish piece of the clay, use tons of lube, and don't apply much pressure when guiding the clay back and forth over the surface. Also - don't reuse dirty clay!
- JT
Old 03-29-2005, 01:18 PM   #8
quattro_silver
Default I have clayed, this is where the spoke meets the lip though, and clay seems innaffective.
I spent about 2 hours on this 1 rim claying. I will get pics up, but basically the spots that I can't seem to get clean are the corners of the spokes, where they meet the lip area. The clay doesn't seems to get everything, it does a great job on the spokes, but the corners remain dirty. I havn't used any type of tar remover, as I was afraid to damage the clear coat, but it looks like I may need to try something.
b5 s4
apr 93
neuspeed g2 exhaust
piggies
kuhmo mx
phatbox
podi boost gauge
Old 03-30-2005, 09:36 AM   #9
quattro_silver
Default I have some turtle wax 'bug & tar' remover, says it's safe on paints.
I was going to try this to remove the tar in the corners. Is there anything harmful that this stuff might do?
b5 s4
apr 93
neuspeed g2 exhaust
piggies
kuhmo mx
phatbox
podi boost gauge
HTML code is Off
