Go Back   AudiWorld Forums » Audi Models » Other Audi » Turbo Quattro Coupe / Ur Quattro / Sport Quattro Discussion
Old 06-13-2006, 08:53 AM   #1
sandwich
Default Will an aluminum radiator....
provide sufficient cooling without the aux. unit?
Just curious...I want maximum assurance that the engine will not overheat.
sandwich is offline   Reply With Quote
Old 06-13-2006, 09:25 AM   #2
Katman
Default Even a stock rad...
Even a stock rad will pretty well work in all situations. Works ok for me, but then, I've never tracked the urq either.
In fact, I've never seen anyone that had problems after removing the aux rad.
Anyone?
-Frank-
"The Twins"
www.frankdekat.com
CGT/4K Frapper map
Plenty Many Audi Pictures!
Katman is offline   Reply With Quote
Old 06-13-2006, 01:05 PM   #3
1984cgtturbo
Default Re: Will an aluminum radiator....
Aluminum radiator will provide abundant cooling. I was driving through the CA desert at speeds higher than indicated on any signs I saw, with the A/C on at full blast and had no issues at all.
Although I do know folks with stock radiators that don't have problems either.
J.
1984cgtturbo is offline   Reply With Quote
Old 06-13-2006, 01:49 PM   #4
stevenmurray
Default Frank - you should mention that you live in Alaska (or there abouts).
stevenmurray is offline   Reply With Quote
Old 06-13-2006, 04:28 PM   #5
Katman
Default Funny Guy, that Steven fellow..! :-)
If that's true, then you must live in Northern BC!
I'm only about 200 miles north of you. Southern Ontario gets summer somtimes too, you know!
-Frank-
"The Twins"
www.frankdekat.com
CGT/4K Frapper map
Old 06-13-2006, 05:31 PM   #6
squidix9
No Bozos!
squidix9's Avatar
Send a message via AIM to squidix9 Send a message via MSN to squidix9 Send a message via Yahoo to squidix9
Default No problems
On 90's the aux rad was designed to fail, so most of them are gone. Unless it's way too hot outside and you're trashing it, you shouldn't have any problems.
I have an aluminum rad without the aux pushing a few more HP than stock and it does run hot, but as long as I keep moving it's fine.
squidix9 is offline   Reply With Quote
Old 06-13-2006, 05:53 PM   #7
sandwich
Default Re: No problems
Were you at a rally cross in the Rochester area late last summer? I saw your car, have a few pictures of it (nothing great). If so, which guy were you? I had the conquest.
-Andrew
Old 06-13-2006, 06:07 PM   #8
squidix9
No Bozos!
squidix9's Avatar
Default Yes
Which guy was I? Not sure how to answer that one, maybe the fast one...ha!
I've been running out there for years on and off. When I have a car that's running, that would be an on.
I'd like to see the pictures in any event.
I also used to run my 90 out there. Check my pic poster for those shots.
Old 06-13-2006, 06:11 PM   #9
stevenmurray
Default I see 'sandwich' visits Rochester - at first I wondered if he lives down south.
Old 06-13-2006, 06:30 PM   #10
sandwich
Default nope, syracuse/boston area, thanks for the replies
