Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 4000 / Coupe GT Discussion
Old 08-31-2005, 04:53 PM   #1
M1LL10N
Default Compression and turbos??
As nooby as this may be...I'm going to ask.
How can some cars run a compression of 11 with twin turbo and some cars need lower compression to run a turbo setup. I'm not understanding it. Can some explain this to me please? Thank you for your replies.
Present
'92 VW GTI 8-valve
'04 Audi S4 4.2 V8 Nogaro Blue - For Sale
Past
'90 Audi 90 quattro 20v Black
'90 Audi 90 quattro 20v Pearl
'87.5 Audi Coupe GT 10vt Tornado Red
M1LL10N is offline   Reply With Quote
Old 08-31-2005, 08:10 PM   #2
Spannerhead
Default Combustion chamber design.
It's all about the combustion chamber design that is the most effective in suppressing detonation. Ideally you want to keep the air as turbulent as possible once it is sucked/pushed into the chamber. This has the effect of slowing combustion and keeping detonation at bay. Combustion speed is cardinal--after all, that's all higher-octane gas does for you, effectively: it burns more slowly and thus resists detonation.
Chamber design is why an engine with an 8.5:1 compression ratio can sometimes be more prone to ping than one with 10:1.
Hemispherical chambers (as opposed to wedge, like our 10V engines) are generally better at creating turbulence and promoting uniform combustion. It's one of the big advantages of OHC engines--they allow greater flexibility in combustion chamber design. Obviously it's not a hard-and-fast rule, as Chevy makes their wedge-chambered SBC work very well indeed.
Hope that answers your question.
Sold:
Spannerhead is offline   Reply With Quote
Old 08-31-2005, 11:13 PM   #3
mhb_1323
Default Re: Compression and turbos??
chamber design + twin turbos dont always mean more boost, most inlines just use 1 to spool the 2nd quicker resulting in less turbo lag, although a V uses 1 for each bank. you can also run water injection which GREATLY reduces pre-detonation, my friends 87 subaru loyal (total sleeper) has a 2.2 turbo motor, 9 (i think) to 1 compression with water injection and can run 16 Lbs of boost easy. and even more if he got a bigger turbo. its possible to turbo an NF or NG, which ever has 10:1, but you either need VERY high octane, water injection, or both to redunce pre-detonation.
Everybody has to learn stuff from somewhere.
mhb_1323 is offline   Reply With Quote
Old 09-01-2005, 02:11 PM   #4
M1LL10N
Default Got It, Thanks :)
Present
'92 VW GTI 8-valve
Past
