Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 4000 / Coupe GT Discussion
Old 08-30-2005, 12:04 PM   #1
Sallad
Default What the crap!?! Starter stopped working.
Hi all...
I pulled into a parking stall, walked into a store 2 mins later I come out and the car wouldn't start!
I have full power with everything. And it fires right up when I push start it.
Could this be just a messed up starter wires? (searching on that now) Before this happened it did seem like the starter was struggling once and a while. But I just assumed it was because of the 20w50 oil and colder mornings.
Ahhhh, this is starting to **** me off.
Thanks everyone.
_____________
Dallas
'86 4kq [Titan Red] (Sold)
'86 4kq [Black w/Blue Pearl] (dead)
'87 4ks 2.2L [Saphire Metallic] (dead)
Kelowna, BC Canada
Sallad is offline   Reply With Quote
Old 08-30-2005, 12:23 PM   #2
CGTBrad
Default must be the cheap gas ;)
j/k I'd check for voltage at the starter. The wires are a good place to start; as it gets pretty hot there.
Brad B.
Nashville
1987.5 CGT 2.3 Special Build
2001 TT 225
CGTBrad is offline   Reply With Quote
Old 08-30-2005, 12:35 PM   #3
1984cgtturbo
Default Re: Could have the wrong air in the tires. :- P
I've had a few starters go over the years, there is usually some indication that it is getting weak. Slower turnover, clicking, etc.
1984cgtturbo is offline   Reply With Quote
Old 08-30-2005, 12:40 PM   #4
AudiCGTSB
Default It might be a sticky solonoid on the starter
As I think I have this problem also. Does anyone know if you can lubricate the solonoid?
AudiCGTSB is offline   Reply With Quote
Old 08-30-2005, 03:39 PM   #5
4corners
Default Key in upsidedown??
4corners is offline   Reply With Quote
Old 08-30-2005, 06:00 PM   #6
Rally_nutcase_1982
Senior Member
Default Does it make the starting "clicking" noise? If not then I'd start investigating
the magnet switch. If it does engage the magnet switch (engages the fork to pull the starter gear in place) then my next guess would be that the Brushes are too low or totally gone (if this starter has brushes of course).
This is just a blind guess because I haven't taken out the starter yet, but the little I know about these things - this is what I'd check.
First the cable connections of course ;-)
Good luck!
Every good driver has bugs stuck to his door windows - do it sideways ;-)
Visit us @www.motoring-foundation.com
or the ACNA-NJ Chapter
Rally_nutcase_1982 is offline   Reply With Quote
Old 08-30-2005, 06:13 PM   #7
powerkraut
Elder Member
Default same thing happened to me twice, bus cable both times.
that steel-wool looking copper braid between the solenoid and starter motor corrodes away after all these years. i'd check that, get something plastic in behind it and see if it's severed. i fixed mine with a 3-wire braid of 12/2 copper house wire and 2 ring terminals coated in liquid electrical tape... still works today too.
powerkraut is offline   Reply With Quote
Old 08-31-2005, 05:54 AM   #8
Cdn Blue Coupe
Default What do you expect if you don't change the air in your tires every 3 months
<font color="blue"><big>Cdn Blue Coupe</big> </font>
85 Coupe GT, 2.2 kx,
custom cold air intake
suspension by boge
87.5 tornado red cancer coupe
"who doth givith his organs so that his brothers may live"
Cdn Blue Coupe is offline   Reply With Quote
Old 08-31-2005, 09:58 AM   #9
Sallad
Default You guys are idiots! (lol) (kidding) :P
_____________
Dallas
Kelowna, BC Canada
Old 08-31-2005, 10:01 AM   #10
Sallad
Default UPDATE: Thanks everyone so far.
Well I jacked it up and crawled underneath. I checked for voltage on the main wire (yellow) and I'm getting a full 12 volts. All the other wires "look" fine. A few strands are frayed on one of the smaller ones, but 85% intact. I felt the copper braid and it "feels" intact as well. I'll try to slip something small in there to see if it's broken.
The only "clicking" sound I get is from under the dash. Sounds like a relay or something. Other than that, the starter is quiet when I try to crank it over.
Worse come to worse, I make a trip to the junkyard. There are 3 4ks's there, so I'll just grab another starter.
Thanks again everyone for your suggestions.
_____________
Dallas
Kelowna, BC Canada
