Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 4000 / Coupe GT Discussion
Old 07-24-2005, 06:24 PM   #1
FourRings
Default Replaced fan switch and thermostat this weekend...
Freaking power steering pump.
Anyways, my fan isn't coming on (not that it was before, thus the replacement) when the car has been turned off. It will come on if I turn the key back to the 1st position but when I turn the key off again, the fan stops. Is there possibly a relay missing or is this normal?
Quote from my girlfriend: "Why is it not hard for me to imagine you living in the woods somewhere, making bombs?"
Rob
Currently:
1978 Rabbit (complete restoration)
1981 4000 5+5
1997 A6 Avant
2006 GTI
FourRings is offline   Reply With Quote
Old 07-24-2005, 07:28 PM   #2
AudiSport4000
AudiSport4000's Avatar
Send a message via AIM to AudiSport4000 Send a message via Yahoo to AudiSport4000
Default When does it turn on?
Does it turn on with the ignition on after a drive and the car has gotten up to temp? If so, its completely normal. My 4k does it after its been running hot and I turn the car off (if I turn the ignition on again, the fan turns on).
AudiSport4000 is offline   Reply With Quote
Old 07-24-2005, 09:06 PM   #3
FourRings
Default Re: When does it turn on?
It will turn on when the needle is getting close to the 2nd bar from the top of the gauge and go off after a few minutes. If I stop the engine while the fan is running, the fan shuts off. If I turn the key back to the 1st position, the fan starts up again.
Rob
Currently:
1981 4000 5+5
1997 A6 Avant
2006 GTI
Old 07-24-2005, 09:29 PM   #4
AudiSport4000
Default Sounds normal to me
Old 07-25-2005, 03:46 AM   #5
85-4kq-girl
Default Yep, to me too (a pic for reference):
She used to not kick on till between the 2nd and 3rd line from the top. But after replacing the thermostat, this is the hottest she'll get before kicking on, and is usually on at the line just under my little red arrow:
--morgan
www.s4girl.com
www.audi4000.com
95urs6--96a4--01s4--04allroad
RIP OWK.
85-4kq-girl is offline   Reply With Quote
Old 07-25-2005, 05:35 AM   #6
cgtdenmark
Junior Member
Default Sounds normal to me also
my fan afterrun system will only kick in, if its REALLY hot.
cgtdenmark is offline   Reply With Quote
Old 07-25-2005, 01:06 PM   #7
FourRings
Default No, the fan comes on just fine, it's just that it won't stay on after I shut the engine off.
Is it normal for the fan not to run when the engine has been shut off?
Rob
Currently:
1981 4000 5+5
1997 A6 Avant
2006 GTI
Old 07-25-2005, 01:22 PM   #8
85-4kq-girl
Default Yep, that is normal. It will shut off. This differs from later models...
I know in my mom's 1988 90q, her fan stays on after you shut the engine off. My S4 also has an after-run fan that remains running after the engine is off. This is NOT the case with 4kqs...so yours sounds normal.
--morgan
www.s4girl.com
www.audi4000.com
RIP OWK.
Old 07-25-2005, 01:26 PM   #9
AudiSport4000
Default Of course...
Your situation sounds very normal. Only on hot hot hot days will the fan turn on when the car is off and key is not in the "on" position. It may take a minute or two after shutdown for that to happen anyhow.
Old 07-25-2005, 01:57 PM   #10
FourRings
Default Ok, cool. As long as I'm not the freak of the bunch, you know. Thanks all.
Rob
Currently:
1981 4000 5+5
1997 A6 Avant
2006 GTI
