Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 4000 / Coupe GT Discussion
Old 03-09-2005, 01:27 PM   #1
coupe diem
Default How to run the throttle cable? (question for turbo guys)
I'm coming to the final stages of my swap and the little details are starting to haunt me. I was just wondering how anyone who has done the swap ran their throttle cable and linked it to the actual lever that opens the butterfly valve. On the 5000 it runs the cable down to the transmission and then there's all kinds of linkage and what have you, and on my old coupe the throttle it just ran the valve directly. So far i'm thinking that this is going to have to be a custom job, but if there's something i'm missing please enlighten me. Thanks.
coupe diem is offline   Reply With Quote
Old 03-09-2005, 01:45 PM   #2
ATMOS
Member
Default I've thought about this briefly...
From what I've seen you'll have to figure a custom way. But let me know what you come up with. I'm about 3 or so weeks away from hooking mine up
Greg J.
Honolulu, Hi.
ATMOS is offline   Reply With Quote
Old 03-09-2005, 02:44 PM   #3
JaredhCGT
Junior Member
Default if your using an MC you just need a URQ throttle cable...
not sure i completly understand your issue... is there something more complicated on the other turbo motors??
JaredhCGT is offline   Reply With Quote
Old 03-09-2005, 07:10 PM   #4
4ktq
Default A couple ways
It sounds like you have an automatic donor car because of how you describe the linkage from the transmission to throttle. Keep the bar coming from the throttle going to the first pivot point at the back of the intake manifold. Use your 4000 valve cover and throttle cable to pull this pivot similar to the stock 4000 throttle lever.
I used an urq cable but since my donor was automatic I had to modify the throttle end of the cable. The manuals look like your 4000 does. The autos have a ball and socket instead of the black cable guide and clip. To adapt the cable I cut one of the ball/socket ends off an automatic linkage bar, drilled a small hole in it near the socket, fed the cable through the open end and out my hole, then hammered the thing flat against the cable. It's held up that way for several years now.
My roommate used the 5ktq cable which works great at the throttle end but needed some sort of adaptation to the 4000 pedal.
Hope this helps.
-Derek L.
'86 4ktq '90cq20v '77 Lancia Scorpions x2
4ktq is offline   Reply With Quote
Old 03-09-2005, 07:48 PM   #5
JaredhCGT
Junior Member
Default Re: A couple ways
Im not using my UrQ throttle cable or manual 5ktq throttle body if someone wants them cheap. Might make things a bit easier.
Jared
Old 03-09-2005, 07:54 PM   #6
AudiSport4000
AudiSport4000's Avatar
Send a message via AIM to AudiSport4000 Send a message via Yahoo to AudiSport4000
Default YGM
AudiSport4000 is offline   Reply With Quote
Old 03-10-2005, 05:26 AM   #7
JaredhCGT
Junior Member
Default the email attached to my account here is wrong...
DJaredHourihan AT hotmail DOT com
Old 03-10-2005, 01:04 PM   #8
Mardkins
Default Thats how I did it
Pat Martin
95 S6 Avant, IA Stage III, 18x8 RS knockoffs. 255/30/18 Yokohama Avid S-4s,
86 4kcsq turbo, MC and loving it, Coil overs holding it up, Momo wheel turning it, harnesses holding the carbon units in place, 944 intercooler keeping it as cool as ever
2005 Allroad 4.2, Green with Green interior, Kermit found a home.
98 A6q Avant. Gone but missed
97 Ford F350 Crew cab, 4x4, GGGGGAAAAAASSSSS. Never met a gas station it didn't like.
Mardkins is offline   Reply With Quote
