Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 4000 / Coupe GT Discussion
Old 07-21-2001, 06:06 AM   #1
dc2002
Default HELP! I failed emissions!!! CO level too high
They test for Hydrocarbons, NO, and CO. Everything else was well below the max level. The CO level was just over the max. Any suggestions before I go for my re-test.
Thanks in advance
'99 A4 Avant 2.8 Tip
'01 Disco II SE7
dc2002 is offline   Reply With Quote
Old 07-21-2001, 08:06 AM   #2
MikTip
AudiWorld Expert
Default Yah! Have it adjusted. There's a small allen head adjustment inside the fuel metering assy. for CO.
2004 A4 1.8t USP Quattro 6MT
K04-15/APR/TT 225 Injectors/Custom Stainless Exhaust/710N/RaceTec FMIC
034 HFC/Jet-Hot Cermi-coated & ported exhaust manifold
Spec Stage 3+ with OE DMFW!
Neuspeed TIP/Neuspeed Snub/Optima 75-35/AFE Pro-Dry/FSI Coils
AMS Short-shift @ %40 redux(Sweet!)
ST Coils/ H-Sport Anti-Sway bars/E-codes
19x8.5 OEM Audi Skinny Fives with 235-35 Bridgestone 760 Sport Skins
B7 A4 brakes with StopTech Ceramic pads and Stop Tech rotors
Sirius Satellite Radio
Ross-Tech HEX-USB+CAN Equipped
Escort 9500ix
MikTip is offline   Reply With Quote
Old 07-21-2001, 08:37 PM   #3
Evilclown
AudiWorld Uber User
Default There's a thread on it a bit further down this forum. What year/model car?
Evilclown is offline   Reply With Quote
Old 07-22-2001, 01:39 PM   #4
AudiSport4000
AudiSport4000's Avatar
Send a message via AIM to AudiSport4000 Send a message via Yahoo to AudiSport4000
Default Change the cat!
AudiSport4000 is offline   Reply With Quote
Old 07-22-2001, 04:30 PM   #5
dc2002
Default Re: There's a thread on it a bit further down this forum. What year/model car?
A 1984 4000S quattro
'01 Disco II SE7
Old 07-22-2001, 08:02 PM   #6
Evilclown
AudiWorld Uber User
Default Hmm, that's CIS-E, isn't it? The procedure is much the same, except...
that you need a voltmeter with a special connector to splice into the differential pressure regulator sockets to get the duty cycle reading. aside from the type of meter and the way it's connected, the procedure is pretty much the same.
Old 07-23-2001, 06:35 PM   #7
MikTip
AudiWorld Expert
Default Re: CIS-"E" did not appear until 1987 and later 4000's 80's 90.
Adjustment can be done with plain wire, no "special" connector needed.
An 1984 4000 has "mechanical" CIS, with the warm-up reg.
Escort 9500ix
Old 07-23-2001, 07:52 PM   #8
Evilclown
AudiWorld Uber User
Default Follow the post as written, then.
2001, a4, co, emission, emissions, fail, failed, high, level, levels
