PowerSteering/Brakes
Old 02-10-2009, 09:12 PM
burtongoods's Avatar
Default PowerSteering/Brakes
In the middle of the winter a problem with my power steering arose, making it extremely difficult to turn the steering wheel. Sometimes it's as easy as it should be but others not. My power steering fluid is low but not empty, any suggestions?
Also around the same time my brakes got real hard. The pedal is extremely hard to press yet again other times easier. My ABS light is always on in the dash. and the on/off button doesnt work on the console. Wondering if it's an ABS problem or other....(rear rotors have rust build up so I'm pretty sure the rear brakes aren't working properly either)
HELP!
Old 02-10-2009, 09:38 PM
Banned
AudiSpaulding's Avatar
Default top off your hydraulic resevoir, it's used in the power assist steering as well as for brake booster
the abs thing is a whole other fiasco, considering pushing the button does nothing, I'd be that the fuse in the abs relay is blown(under the dash in the cluster of relays, think its the only one w/ a fuse under there) or if the relay is even in there. the abs sensors need to supply equal readings from left to right in order for it to work correctly, if the sensors have been removed it can be hard to get them back in correctly
Old 02-11-2009, 04:16 PM
5000Q86's Avatar
Default ^^Second^^
these cars use a form of hydroboost for power steering and braking. check the rack and pinion seals. that was the cause of my loss of fluid in my 100.
Old 02-13-2009, 12:40 PM
Zdenda12's Avatar
Default Re: ^^Second^^
same problem (fluid loss) - yesterday: new hoses from hydro pump to servo, new sleeves, new pump, new fluid - now ok
ABS problem could be in dirty senders on wheel hubs, check SJM for info
Simonasc6
03-05-2018 05:40 AM
msandhu413
A7
12-08-2016 09:30 AM
rogman897
04-04-2010 08:24 PM
adminisTerTurbo
TT (Mk1) Discussion
02-21-2006 02:31 PM
atrak
02-13-2003 08:28 PM
Quick Reply: PowerSteering/Brakes
