Old 05-23-2008, 12:45 PM   #1
gedis080
gedis080's Avatar
Send a message via Skype™ to gedis080
Default brakes from Cayenne Turbo instead UFO (sorry, again...)
Finally I found these ones callipers second hand for fair price and 360mm brake discs....I hope everything will be OK .....
P.S. I still want to keep UFO housings and I remember this:
signature: http://postimage.org/image/pn3kmg0on/
gedis080 is offline   Reply With Quote
Old 05-23-2008, 02:37 PM   #2
itsav8
Default Gedis......
...I will say that you can make anything work with the rite amount of $$$$$ ;-)
Brackets are self explanitory since you can have them made. But,
rotors will be difficult to source off DER shelf. You have to find a rotor that has the proper offset to match the brackets to give you the proper spaceing.
Now if it's money you wanna spend you can have custome rotor hats made & use an off DER shelf Willwood or Coleman rotor ring. You might even find a Porsche rotor ring to work as well.
One other thing as it pertains to the rotors. You'll find that the UFO hubs are unique to themselfs. If you compair that hub to a Urs car hub found on the Mcferson struts that people usually use.
In any event, good luck with your resurch & keep us informed on what you find.
thanx
Ron
2.6l 20vt stroker motor W/O a roof
91 V8 5sp mit 4.2 aka Black Betty
91 200 20v 22psi
90 v8q 3.6 not stock...gone but not forgoten :-(
itsav8 is offline   Reply With Quote
Old 05-25-2008, 07:15 PM   #3
200Q20v
200Q20v's Avatar
Default need to worry about
upsetting brake bias and having enough fluid to move those huge brakes.
200Q20v is offline   Reply With Quote
Old 05-26-2008, 08:37 AM   #4
itsav8
Default Think x2 MC setup ;-) Those Cayenne Turbo calipers are 6 piston?
thanx
Ron
91 200 20v 22psi
audi, brakes, cayenne, ufo
