Old 01-07-2008, 04:47 PM   #1
rightturnclyde
Default 1st time with warmed- up start concern
After a long 65 degree day, I drove my 1990 200q for about 30 minutes.Toward the end of my drive my brake pedal had about an inch of freeplay before hitting solid pedal. That I believe is my master cylinder. Brakes seem to hold on after this starts to happen. Doesnt happen when cold. Anyways, not the point. Came out of the store after about 10 mins of shopping. Car would crank, stumble, then stall out. After waiting about 10 mins, car started right up (as best as it does, It always take 5 or so seconds to start)
And drove away fine, although I was a little less confident. Made it home without further issue. Any suggestions??
rightturnclyde is offline   Reply With Quote
Old 01-07-2008, 04:55 PM   #2
AK_92_V8
Default i get that sometimes it helps of you turn the key all the way before starting it and let it sit
there for about 2 seconds then crank it. at least it helps me
AK_92_V8 is offline   Reply With Quote
Old 01-07-2008, 05:25 PM   #3
V8QinNJ
Default Re: 1st time with warmed- up start concern
Check SJM's site for the Ref Sensors troubleshooting.. Those are the "tell tale signs" you got there..
-Scott
_________________
Scott
'90 V8 Quattro Papryus Metallic (SOLD)
'90 V8 Quattro Pearl Metallic
'90 V8 Quattro Crystal Silver Metallic
'90 V8 Quattro Pearl Metallic (Parts)
V8QinNJ is offline   Reply With Quote
Old 01-08-2008, 05:41 AM   #4
jurq
Default what effect does that have?
1984 Scirocco MkII
1991 200 20v quattro Avant
jurq is offline   Reply With Quote
Old 01-09-2008, 04:48 AM   #5
itsav8
Default Fuel pressure problem^^^^^^^^^^^
How's that FPR look Kyle?
thanx
Ron
2.6l 20vt stroker motor W/O a roof
91 V8 5sp mit 4.2 aka Black Betty
91 200 20v 22psi
90 v8q 3.6 not stock...gone but not forgoten :-(
itsav8 is offline   Reply With Quote
