#1 | ||
#2 |
Austin 92 urs4 91 200 20v 90 90q 20v 88 5ktq avant |
#3 |
Runs fine when rolling, no hesitation? Could it still be the filter.. I am thinking that may be it, not sure why
Thanks, Anthony '89 90Q |
#4 |
Other than that I'd say it may be time to suspect the CIS dizzy or the ECU. Can you pull codes from your ECU?
Cheers; Boxerfan Toronto, Ontario CANADA 1983 Ur Quattro. RS2 Replica turbo, Custom 8.5:1 CR Pistons, sleeved block, MC2 cam, micropolished crank, shot-peened rods, 20VT HG, ARP Head Studs, Supertorque T-belt set up, BPV, Dual diaphragmed WG, chipped ECU, D-ported intake runners, 7mm stem Ti valves, aluminum oil pan, rear sway bar, 5-point harness. "Essica" Current project: 1983 Ur-Quattro Club Rally car. Still needs engine and transmission... and a number of other things. "Adam Bomb" ATTRITION LIST: 1987 Coupe GT. 98,000 original kms, tornado red. "Rosie". Sold. 1988 Olympic Edition 5000 CD Turbo Quattro Avant. "Red Devil" - Sold 1993 Audi V8 Quattro 5-speed conversion, IA chip set, short shift kit, full dual exhaust with 911 Turbo cats. "The Blue Meanie" - Sold 1990 Audi V8Q Pearl - Demolished. 1990 Audi V8Q Pearl - Sold 1989 Audi 200Q Black- "FrankenAudi" Alive again! - Deceased - Taken off the road by ERASE (Eliminate Racing Activity on Streets Everywhere) - Sent directly to crusher, do not pass GO, do not collect $200. 1989 Audi 200Q Avant Black - "FrankenVagen" Deceased May 7th, 2006 - Cause of death: Front end removed in collision - Boy in Ford Expedition SUV ran red light doing 70kph. 1989 Audi 200Q Sedan Tornado Red - "Cherry Bomb" Deceased January 19th, 2004 - Cause of death: Rear end collision - Girl on phone in Buick doing 80kph. |
#5 |
thanx Ron 2.6l 20vt stroker motor W/O a roof 91 V8 5sp mit 4.2 aka Black Betty 91 200 20v 22psi 90 v8q 3.6 not stock...gone but not forgoten :-( |
#6 |
1990 Audi CoupeMy Garage Join Date: Nov 2001
http://coupe.gofergusons.org "SECRETARY OF ENERGY AND AE ASSWHIPPINGS: We call him when we need a big plane that kills people." |
#7 |
#8 |
If I unplug the O2 sensor, what will happen to the car, it will still start and run right?
thanks, Anthony '89 90q |
#9 |
#10 |
throttle and the 7A throttle. The 7A has idle, WOT and a TPS on it, which makes it nice to use when converting a 10vt to EFI. Just grab a ur-NF intake manifold and 7A throttle body w/connector.
| Tags |
| audi, connection, vacuum, wur |
