Old 07-10-2007, 12:48 PM   #1
-0000-NH
Default '90 100 i5 rough idle /surge..
just recently started.
idle adjust?
dirty tb?
dirty air sensor?
plugs look ok
needs oil change soon.. oil flush?
Never take life seriously...
Nobody gets out alive anyway.
Hi, Im Sean, Im from Rochester, NH and I have too many ideas for my own good. Thank you.
*applause*
'86 4000cs quattro CE
Alpine White / Red Leather
working toward 100% working OEM cond.
then... ice racing?
Eulia
*needed list*
passenger seat slide rail plastic "stop"
passenger seat slide rail plastic cover
driver side upper headlight trim
turbo engine
light-grey "oh-****" handles
screw for glovebox hinge to lower dash
steering column cover screws
power antennae
door "open" switch rubber thing
turbo engine
dash gauge frame (both screw points cracked)
cast power steering pump mount
door lock catch pins - all 4 (or just the plastic sleeves, if replacable)
turbo engine
interior door handle bezel srew covers
driver side headlight aiming screw assembly
visor clip
flimsy plastic rain cover for hvac
mud flaps
turbo engine
*available*
complete AC system except for evaporator (missing)
'92 Isuzu Amigo XS (extremely sexy)
Black/grey fuzzy stuff
currently undergoing drivetrain & suspension upgrades..
-0000-NH is offline   Reply With Quote
Old 07-10-2007, 05:30 PM   #2
rooster 2
Default pull the diagnostic codes............
suspect it may need an oxygen sensor. I bet it has been a long time since the sensor was replaced.
rooster 2 is offline   Reply With Quote
Old 07-10-2007, 06:46 PM   #3
-0000-NH
Default I dont know anyone with a reader..
..and the nearest audi dealer is quite a drive.
i suppose we could go to Autozone and see if they can plug in...
*applause*
then... ice racing?
Eulia
*needed list*
turbo engine
power antennae
turbo engine
turbo engine
visor clip
mud flaps
turbo engine
*available*
Old 07-10-2007, 09:19 PM   #4
MrGoodbytes
Default Re: I dont know anyone with a reader..
Most FLAPS can only read domestic OBDI
Try here for reading your own codes:
http://www.sjmautotechnik.com/troubl...g/100ecuf.html
¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯2000 A4 2.8 quattro [ Tip | Sport | Xenon ]¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
MrGoodbytes is offline   Reply With Quote
Old 07-11-2007, 05:14 AM   #5
geefunck88
Default Re: '90 100 i5 rough idle /surge..
i made a code reader with an led and a few extra pieces of wire. costs about 3 bucks for the resistor and an led. look at sjm website. they show you how to make it and how to use it. the led flashes out the numbers to make up the code. for example two flashes = number 2
geefunck88 is offline   Reply With Quote
Old 07-11-2007, 05:33 AM   #6
-0000-NH
Default oh neat.. ill try that tonight
*applause*
then... ice racing?
Eulia
*needed list*
turbo engine
power antennae
turbo engine
turbo engine
visor clip
mud flaps
turbo engine
*available*
90, audi, idle, surge
