Old 06-03-2007, 06:06 PM   #1
Chad T
Default EZ 200 Dash Switch Illumination Repair With Lots O' Pics
Hey Guys & Gals,
Car is running pretty well and I got bored this weekend so I decided to treat her to some new switch illumination.
I found a few DIYs on this that were very helpful but none specific to the 200 so I decided to photograph everything and do a breif how to.
This was way easier than I thought it would be from reading how to do it. Hopefully these pics will make it seem as easy as it is.
I'll start with the seat heater lights:
First thing to do is remove the switch. Just gently pry on the top and bottom until it comes out. You have to reach back in there a bit to avoid just pulling the outer switch cover off.
Once it's loose you can pull it out and seperate the switch assembly from the harness connector with a screwdriver.
Next find a nice clean spot to dis-assemble the switch and do some soldering. I used the kitchen table.
Getting the switch apart is one of the more difficult operations. You need to pry it with a knife or something thin. It's not hard to get apart it's just hard to get anything in there.
Be careful not to lose these clips as they tend to fall out.
This is what the inside of the switch looks like when you get the cover off.
Now you just have to seperate the circuit board from the switch. It's held together with some melted plastic pins.
I tried cutting them but this was very awkward and not very effective. A small screwdriver under the pins workes perfect. Just a little twist pops them loose easily.
Just lift the switch assembly off the board to expose the bulb.
It's best to leave the roller inside the red plastic piece and set it aside like this.
I took the first one apart and then remembered hearing about this little ball that always gets lost. Of course when I looked it was gone but luckily it landed in my lap.
Back in it's proper place.
OK time to get that bulb out. This requires a 30 watt soldering iron and a solder sucker. You could also use a wick but I like the sucker much better. Soldering iron was $4.95 with a case, solder and a stand and the sucker was $1.65 from an on line electronics place so don't be afraid to go out and get these.
All you have to do is carefully heat the solder until it's liquid and then hit it with the sucker. The sucker will pull the solder right out.
Here the bulb is free and you can see the solder that came out of the sucker.
Radio shack 12v 60mA bulb is pretty much an exact match. I had gotten this info from some of the existing write-ups. $1.49 for 2. I splurged and got 4 which was all they had.
I left the leads on the bulb long until I got it soldered. Made it easy to hold the switch at a good angle for soldering. Note the plastic sleeve re-installed on one leg of the bulb.
To solder the bulb I just heated what was there and then added a bit.
Now just cut the excess off of the bulb leads, set the switch back on the board and slide it back in to the housing. The housing will be holding the switch together since the red melt pins are gone. Works fine as it's a nice tight fit.
Time to re-install the switch. Previous writed ups said to either remove the radio or an adjacent switch to hold the plug which is now pretty much dangling behind the dash.
I just grabbed it with some needle nosed pliers and then wedged it with a screwdriver to hold it in place so the switch could be pushed on to the plug. This worked out very well.
That's pretty much all there is to it. Did both switches in about 45 minutes or so. Very easy...but not as easy as the lights in the other switches.
I actually removed the anti-lock switch and took it in the house and dis-assembled it before I realized you can simply pull the cover off and change the bulb. It has a different bulb from the heater switches. The bulb simply pulls out.
This has to be the simplest Audi interior bulb change there is.
1. Pry off switch cover.
2.Pull out bulb with pliers
3.Buy 12v 1.2w small bulbs at local FLAPS.
4. Insert new bulbs and push switch cover back on.
Now enjoy full dash switch illumination!!
P.S. Should my Anti-lock switch be lit all the time?
Chad T is offline   Reply With Quote
Old 06-03-2007, 06:21 PM   #2
sieben
1991 Audi Quattro
Default beautiful information and detail. will come in handy when the V8 needs the same :thumbup:
Changing tails from red to amber, one car at a time. ;-)
2001 S8 - 1st S-car (ACHT ZWO)
1991 V8Q ABH/DQT/ABT/LC1/19# (4.2/ 6MT) the one and only (acht)
2008 Atomic Orange LS3 LT3 U3U 6MT (sechs)
sieben is offline   Reply With Quote
Old 06-03-2007, 06:49 PM   #3
20VT90q
Default Good stuff. Anti-lock shouldn't have a bulb on the bottom, it is not made to light up
when activated.
<U>Project '93 Urs4</U>
-8/'92 Build Date ~Rear Sway/Suspension~
-Suspicion of a chip (cut carpet)
ON THE BED: H&amp;R's, '92 trip computer cluster, Sport Wheel, TDS-1, E-code Headlights, Euro Bumper, A8 Interior Auto-Dim Mirror
<U>'90 20v 90q:</U>
-RS2 Headlights
-16" Borbets
-Manual Climate Swap
-Concert Headunit
-Quattro Scripts (Auto to manual swap)
-034 Injectors
-B4 Hood Conversion
<U>'93 100CS:</U>
-Bad Headgaskets/leaky steering rack
-FWD/Auto Garbage
20VT90q is offline   Reply With Quote
Old 06-03-2007, 06:58 PM   #4
Chad T
Default Should the top be lit without the lights on though?
It stays on all the time. If I push the button it goes out for a second and comes back on. Is that normal?
I might have to read the owners manual.
Old 06-03-2007, 07:04 PM   #5
Adam Mowafy
Adam Mowafy's Avatar
Default I believe the light that goes on and off for anti lock is in the cluster. At least on the 5k....
Adam in Michigan
-90 Audi V8 Quattro *V8 twin turbo*
-90 Audi V8 Quattro
-80 Scout II *complete fiberglass conversion*
-72 Ford Maverick w/302
-72 Honda CB550
Adam Mowafy is offline   Reply With Quote
Old 06-03-2007, 07:54 PM   #6
Chad T
Default Looks like it's normal. Just not used to having it lit up.
Old 06-03-2007, 09:28 PM   #7
20VT90q
Default Normal, as are the lights in the seat heater buttons.
That's why they burn out so often;-(
<U>'90 20v 90q:</U>
-RS2 Headlights
-16" Borbets
-Concert Headunit
-034 Injectors
-B4 Hood Conversion
<U>'93 100CS:</U>
-FWD/Auto Garbage
Old 06-03-2007, 09:39 PM   #8
20VT90q
Default same as all the other cars ;-) (100/V8/urs4/90/etc.)
<U>'90 20v 90q:</U>
-RS2 Headlights
-16" Borbets
-Concert Headunit
-034 Injectors
-B4 Hood Conversion
<U>'93 100CS:</U>
-FWD/Auto Garbage
Old 06-04-2007, 06:37 AM   #9
jurq
Default Well done Chad! Looks great. Will def keep this post for future ref...
1984 Scirocco MkII
1991 200 20v quattro Avant
jurq is offline   Reply With Quote
Old 06-04-2007, 07:03 AM   #10
audi-bahston
Default What is the function of the little ball in the seat heater switch?
One of my switches has tension when you roll the wheel and the other doesn't. Could this be missing the ball?
Very nice write up!!
TIA
1987 4000s FWD 257k - Sold and still alive
1991 200 20vt - 112k - Gone
1991 200 20vt Avant - Under the knife
audi-bahston is offline   Reply With Quote
dash, illumination, repairing, switch
