Airbag light reset/clear
Old 08-23-2006, 05:44 PM
T44Avant's Avatar
Default Airbag light reset/clear
My Airbag light is constantly on. Could someone PLEASE provide step by step directions as to how to clear the darn light.
Old 08-23-2006, 05:55 PM
audiqv8's Avatar
Default Re: Airbag light reset/clear
If the light is on constantly on them there is a problem with the airbag system. You could try to clear the code, but you will need a VAG-COM in order clear it.
Normally if the light stays on for about two minutes, then there is a stored DTC code for the air bag which can be cleared by VAG-COM, but if it is on constantly on then the clockspring could be broken.
Make sure you're sitting down when they quote you the cost of a clockspring at the dealership $$$
Did your battery died?
Did you play around with the steering wheel?
Did you turn the ignition on with the air bag disconnected?
Old 08-23-2006, 06:30 PM
T44Avant's Avatar
Yes.......I goofed when reinstalling the steering wheel (turned the ignition on with the airbag disconnected) and cant get the light off.
Old 08-23-2006, 07:05 PM
audiqv8's Avatar
Just get a VAG-COM and reset the airbag computer, or you can take it to your local Audi dealeship or independent
LukeV
Audi A3 / S3 / RS 3
11-19-2012 07:39 AM
LMSI-G35X
VAG-COM Discussion
09-10-2006 08:35 AM
edial
11-14-2003 05:58 PM
Schlepcar
04-08-2002 05:10 PM
Quick Reply: Airbag light reset/clear
