Old 04-21-2006, 03:50 PM   #1
urluzn2
urluzn2's Avatar
Send a message via Yahoo to urluzn2
Default Brake light on?
What exactly causes the e-brake light to stay on in my 89 200tqa? Calipers locked up awhile back, replaced them. I use the ebrake most of the time when parked, but light stays on most of the time. Sometimes off, or when i go over a bumpy road it flashes around from the bad road. Where do i look? thx
urluzn2 is offline   Reply With Quote
Old 04-21-2006, 04:01 PM   #2
Black-Wolf
Junior Member
Default check your pentosin
Charlotte, MI
2002 A6 2.7T 6speed Sport RS4 Clutch
1994 UrS4 Black/Ecru Lots o'Mods (for sale)
Black-Wolf is offline   Reply With Quote
Old 04-21-2006, 04:46 PM   #3
rooster 2
Default check brake fluid level in the reservoir.
rooster 2 is offline   Reply With Quote
Old 04-21-2006, 05:47 PM   #4
4x5x5
Default Re: Brake light on?
I'd ask which brake light, the one in the information center along with "OK", or the separate small red light indicating e-brake only? If ebrake only, nothing to do with fluid levels but more likely a flakey plinger swith below the ebrake lever.
4x5x5 is offline   Reply With Quote
Old 04-21-2006, 05:51 PM   #5
urluzn2
urluzn2's Avatar
yea its the little red one in the middle that blinks on/off when on bumpy road.
Old 04-21-2006, 06:51 PM   #6
Black-Wolf
Junior Member
Default incorrect:
low pentosin will cause the light to come on as will low brake fluid. if you want to see this go remove the cap from the pentosin res. and see if the light comes on.
Charlotte, MI
Old 04-21-2006, 10:44 PM   #7
S4for73
Default Re: check your pentosin
Also check the screen in the reservoir
S4for73 is offline   Reply With Quote
Old 04-22-2006, 10:30 AM   #8
4x5x5
Default Re: incorrect:
Quite right, quite right. Sorry, brain fart. Red Brake light can mean low fluid, bad bomb, or ebrakes/switch on. Back to your regularly scheduled programming!
Old 04-22-2006, 01:51 PM   #9
qpower
Member
Default low pentosin, brake fluid or bad bomb
qpower is offline   Reply With Quote
