Old 02-14-2006, 01:55 PM   #1
kixbax
Default tach? update
where does the signal wire go o a 5000 turbo? the stock tach does not always work. and if you know do you have a pic of it?
kixbax is offline   Reply With Quote
Old 02-14-2006, 03:59 PM   #2
Adam Mowafy
Adam Mowafy's Avatar
Default ECU Pin out
Adam in Michigan
-90 Audi V8 Quattro *V8 twin turbo*
-90 Audi V8 Quattro
-80 Scout II *complete fiberglass conversion*
-72 Ford Maverick w/302
-72 Honda CB550
Adam Mowafy is offline   Reply With Quote
Old 02-14-2006, 11:17 PM   #3
MarkPan
Default the tach sensor is one of the shielded wires going to the ECU (yellow)
forget the pinout exactly.
its a 15v pk-pk or so sine wave, 135 cycles per revolution.
then the ECU has a line out to the tach. I dont know what sort of signal it sends it though. perhaps just TTL buffered version of the original. maybe something else... frequency dependent voltage perhaps.
MarkPan is offline   Reply With Quote
Old 02-15-2006, 07:38 PM   #4
kixbax
Default Re: ECU Pin out
i an kinda a tard when it comes to a wiring diagram. can you tell me what color the wire is.
thanx
jason
87 audi 5000 turbo
Old 02-16-2006, 05:27 AM   #5
Adam Mowafy
Default just look at the number on the pin........
Adam in Michigan
-90 Audi V8 Quattro
-72 Honda CB550
