#1 | ||
#2 |
Sounds like vapor lock, which the injector cooling fan will help eliminate (if it's operational).
The thermoswitch for this cooling fan has a single wire and is mounted atop the wastegate heat shield. Test it with a heat gun. If the fan never turns on, either the thermoswitch, its relay, its fuse, or the fan (or all four) is kaput. *IF* the injector cooling fan operates and you still experience vapor lock, residual fuel pressure may be low; perhaps the fuel check valve is intermittently failing (which they will do). BTW, the rubber shroud, according to Bosch / Audi, covers the fuel lines to the injectors to both reduce heat soak when off and fire retardation: it prevents fuel from spraying directly on hot engine in case of a fuel line break/leak (God forbid). |
#3 |
Member
VACUUM LEAK?
#4 |
and the injector cooling fan should come on as part of the after-run cooling program. If if does not, then the fan or the fuse is gone. If it comes on, but not during after-run, then the relay is shot. The shroud directs air directly onto the injectors to reduce the liklihood of vapor lock. I would agree with qpower that this sounds somewhat like a vacuum leak, particularly somewhere between the turbo and the intake manifold.
#5 |
Ok, so I know that on that day it was vapor lock that stalled my car. But I also think my thermoswitch for the radiator/after run fan might be blown too. While recently driving the car, I noted that at traffic lights or in stop-and-go traffic it's not coming on. I heard that replacing this thermositch is risky because the threads on the radiator are made of plasic, which becomes brittle and can break when removing the switch. Is this true? I currently have a new thermoswitch for the radiator/afte run fan, but can't decide on what to do.
#6 |
Use a 29 mm deep socket for the radiator fan thermoswitch (on the rear surface of the radiator, just beneath the lower hose). You'll need to remove the lower radiator hose to access it, which means that you'll lose a lot of coolant, so have some fresh coolant ready to refill.
BTW, though the cause of the radiator fan not runnnig when it should may be a defective thermoswitch, a failed relay will also cause the same problem. The after-run thermoswitch for the radiator fan (and coolant pump) is located on the rear surface of the aluminum casting that joins the upper radiator hose to the cylinder head. It has two terminals. |
#7 |
Sergei Pokrovsky and '08 335xi 6 speed Total of 12-wheel drive, 17 cyllinders and 5 turbos of insanity Littleton, CO |
