#1 | ||
Cheers; Boxerfan Toronto, Ontario CANADA 1983 Ur Quattro. RS2 Replica turbo, Custom 8.5:1 CR Pistons, sleeved block, MC2 cam, micropolished crank, shot-peened rods, 20VT HG, ARP Head Studs, Supertorque T-belt set up, BPV, Dual diaphragmed WG, chipped ECU, D-ported intake runners, 7mm stem Ti valves, aluminum oil pan, rear sway bar, 5-point harness. "Essica" Current project: 1983 Ur-Quattro Club Rally car. Still needs engine and transmission... and a number of other things. "Adam Bomb" ATTRITION LIST: 1987 Coupe GT. 98,000 original kms, tornado red. "Rosie". Sold. 1988 Olympic Edition 5000 CD Turbo Quattro Avant. "Red Devil" - Sold 1993 Audi V8 Quattro 5-speed conversion, IA chip set, short shift kit, full dual exhaust with 911 Turbo cats. "The Blue Meanie" - Sold 1990 Audi V8Q Pearl - Demolished. 1990 Audi V8Q Pearl - Sold 1989 Audi 200Q Black- "FrankenAudi" Alive again! - Deceased - Taken off the road by ERASE (Eliminate Racing Activity on Streets Everywhere) - Sent directly to crusher, do not pass GO, do not collect $200. 1989 Audi 200Q Avant Black - "FrankenVagen" Deceased May 7th, 2006 - Cause of death: Front end removed in collision - Boy in Ford Expedition SUV ran red light doing 70kph. 1989 Audi 200Q Sedan Tornado Red - "Cherry Bomb" Deceased January 19th, 2004 - Cause of death: Rear end collision - Girl on phone in Buick doing 80kph. |
#2 |
It doesnt mention MC2, only MC and 1B.
1B and MC up to serial number 039950: 034 109 021 K MC above serial number 039951: 034 109 021 AK the serial numbers coincide with april/march 1988, so I'm assuming engines with numbers above 039950 are MC2's. |
#3 |
Lobe "MON" lobe bearing lobe "W Germ" lobe disc lobe space lobe bearing lobe "035 CB" lobe ring lobe lobe bearing dizzy gear.
Rotate 180 degrees… Lobe "3" lobe bearing lobe "409E" lobe disc lobe space lobe bearing lobe "VW oooo" lobe ring lobe lobe bearing dizzy gear. I don't see any relationship to the part numbers... any ideas? What I thought was a stock MC1 head already had 40mm valves. Who knows what cam might have been installed.
| Tags |
| camshafts, mc |
