Old 04-05-2005, 01:54 PM   #1
thanatos
Default battery - boosting post wire splice
dim battery light and handbrake light all the time on - one of the posts saying about splice corroded in the passenger footwell below (?)the ecu, visible after lifting the carpet. Lifted the carpet the bunch of wires running straight - no splice. Where else would that be if any ? 1990 200 T. Any ideas ??
thanatos is offline   Reply With Quote
Old 04-05-2005, 04:07 PM   #2
RussB
Default The splice exists on my two 5000s . . . not sure about 200
On the 5000s, the alternator side of the splice contains two conductors: the larger one goes to the starter motor / jumper post / alternator and the smaller conductor supplies current to the fuse & relay box on the driver's side of the car.
The 200 may be the same or different -- I don't know. You might wanna see how the fuse & relay box on your car gets its current. I think that I read somewhere that on later 100s / 200s the current is supplied from the starter motor "+" terminal, eliminating the need for a splice.
Russ Bellew
1988 5000CS Turbo Quattro
My blog
http://russbellew.com
RussB is offline   Reply With Quote
Old 04-05-2005, 04:43 PM   #3
Will Ng
Member
Default for the 200.
The battery splice is right below the recirc flap.
Pull back the carpeting, and you'll see a large grommet at the firewall. Main ECU harness, and a few other harnesses go through, also the battery cable. The splice is a few inches from the grommet.
HTH!
R.I.P.
<A HREF="http://members.fortunecity.com/willng/my_audi_200/manual/index.htm">
88-91 Audi 100/200 Factory Service Training Manual</A>
Will Ng is offline   Reply With Quote
Old 04-06-2005, 06:55 AM   #4
thanatos
Default thanks i was looking on the floor only
will double check today by rec.flap
Old 04-06-2005, 08:35 AM   #5
SteveJ_in_TX
Default Go here for details on the fix
Click on search the repair index and then search on the word "splice":
-Steve Jensen
87 5kcstq
SteveJ_in_TX is offline   Reply With Quote
