Old 03-30-2005, 10:56 AM   #1
charles 200TQ
Default Power antennae...
Recently my power antennae quit going up, so I don't get any radio reception. Is there any sort of common problem that can be fixed with them, or is the only solution a brand new one? Checked it out and those things look a bit complex. Any help is appreciated. Thanks.
2001 A6 4.2 Quattro - Beverly
1986 5000CS Quattro - Kelis
1990 200TQ - Oprah (My first love, taken from me by a mudslide... RIP)
charles 200TQ is offline   Reply With Quote
Old 03-30-2005, 11:05 AM   #2
icon73
1987 Audi 5000
My Garage
Default yeah sounds like you need a new one, fairly easy to replace
pull the interior carpet paneling on the drive side of the trunk, you'll see the whole atennae base. Unscrew the cap on the outside of the atennae mast on the body of the car and remove the bracket holding the base inside the car,undue powerleads, pull out old unit, install new, make sure you reinstall the drip line under the base and screw the cap back on the ouside part of the atennae, then your done. Takes more time pull the lining inside then actually replacing the unit, done it twice now on my car.
Chris
87 5000cstq
euro turbo headlights, blau relay harness, 2bennett chipped ecu and 2bar wastegate spring, 3inch cat-back exhaust system, eibach sport spring kit, bilstein sport struts and shocks with v8 upper strut mounts, single pass intercooler, stewart warner boost gauge
82 5000 fwd (miss that one)
icon73 is offline   Reply With Quote
Old 03-30-2005, 05:11 PM   #3
rick5ktq
Default Did you replace it with an OEM or aftermarket?
-Rick
'87 5ktq
'91 Alfa Romeo 164L
rick5ktq is offline   Reply With Quote
Old 03-31-2005, 03:24 AM   #4
icon73
1987 Audi 5000
My Garage
Default OEM replacement, as long as it's a Hierschman(spelling) your good, all others are kinda shadey.
Chris
87 5000cstq
