Old 03-02-2005, 09:08 AM   #1
andysprague
Default Any ideas why my idle will bounce from 1100 - 1300 continuously in a '90 200TQ?
At start up it idles consistantly high till warm then it starts to bounce from 1100 - 1300 continously up & down. It does this 100% of the time.
I took off the ISV & cleaned it = nothing.
I unplugged the ISV = same bouncing.
Searching the archives hasn't really helped.
Anyone have any ideas?
Thanks!
andysprague is offline   Reply With Quote
Old 03-02-2005, 09:38 AM   #2
Suffolk
Default Re: Any ideas why my idle will bounce from 1100 - 1300 continuously in a '90 200TQ?
Unmetered air leaks?
Clogged Fuel Injectors?
TPS?
-Scott by BOSTON
THANKS to all who voted in this month's NAAClub.org's election.
Learn history about the ACNA at http://www.acnasupport.com
-Scott by BOSTON
Driven: (like I had key on my key ring)
74 100LS, 80 4000S, 86/87 4000S/4000Q, 86 5000S, 90 200 Avant, 91 200 20V Avant & Sedan, 99 A4, 99 A6 Avant a few others and MANY rental cars.
NHIS/NHMS, LimeRockPark, WatkinsGlen, MontTremblant, Poconos, VIR, MidOhio, AutoBahnCC - Full, Daytona
Suffolk is offline   Reply With Quote
Old 03-02-2005, 09:47 AM   #3
XcellR8edAudi
Default i would say tps...
Current Rides:
2005 Subaru Impreza WRX STi
1987 Audi 5000 CS Turbo Quattro
Past Rides:
1988 Audi 90 FWD/Auto
1988 Audi 5000CS TQ Avant
1989 Audi 200 TQ
1987 Audi 5000CS TQ Avant
1988 Audi 5000CS TQ
1995 Audi 90 Quattro
1990 Eagle Talon TSi
1992 Subaru Legacy L Wagon
1995 Ford Escort Wagon
1989 Volvo 240 DL
2005 Subaru Impreza 2.5RS
XcellR8edAudi is offline   Reply With Quote
Old 03-02-2005, 01:33 PM   #4
Jon Clay
Junior Member
Default agreed, probably the solder joints have cracked and you need a new one
I soldered mine up but it only lasted a day before they recracked. The new ones have a better design which doesn't lend themselves to cracking.
You could try unplugging the throttle switch and connecting a wire across (I think the bottom two pins) to see if that stabilizes the ISV. Also try cleaning the ISV out with some carb cleaner.
<a href="http://filebox.vt.edu/users/jdubyk/Audi/Index.html">
</a>
______________________
AIM SCREEN NAME: j0n clay (that's a zero in j0n)
Jon Clay is offline   Reply With Quote
Old 03-03-2005, 03:57 AM   #5
comp_jas
Default Re: Your ISV has failed.
I wrote a lengthy post about this called "wild idle".
JAS
'86 4000cs (RIP)
'86 5000CS QT
comp_jas is offline   Reply With Quote
Old 03-05-2005, 10:15 AM   #6
hdtrc
Default Mine does the same thing
I was letting my '89 200QT idle for about 1/2 hour when it started doing the same thing. Aside from test trips around the block, the car hasn't been on the road since I got it for free 20 mos. ago. I rblt the head, had the exh manifold welded (Superior Welding...Pittbrg,PA)and a whole lot of suspension work. The interior gets wet after rains so I let it idle to dry out. Suddenly the idle started swinging from 1000 to 1300. I unplugged the TPS and the revs shot up,unplugged the fuel cutoff and it stabilized but very erratic, unplugged the ISV and nothing changed, ran the throttle bypass screw in and out but little changed, all new seals and gaskets, charged the battery, check alot of stuff. I'll let you know when I fix it.
hdtrc is offline   Reply With Quote
