#1 | ||
#2 |
Are you getting pressure at the fuel rail? The pump comes on briefly when you first turns the engine over, but it doesn't stay on until the engine have started (Audi safety measure to stop the fuel pump in case of a front end collision. Don't want fuel being pumped with the engine stopped could start a fire).
Could also be a bad fuel pump relay or a bad CSV cold start valve. The CSV in another injector located at the back of the intake manifold. This car does not have a choke and the CSV is used to enrich the mixture on a cold engine. Try removing the hose between the intercooler and throttle body, then shoot some starting fluid into the throttle body. See if this will start the car. Fuel will not get to the injectors until the air plate have moves up. |
| Tags |
| bad, distributor, fuel |
