Old 06-29-2004, 05:34 PM   #1
rooster 2
Default bad plastic radiator overflow tank..........how is sensor installed??????????
I replaced it with a good one from a bone yard, but now it leaks where the sensor plugs into the bottom of the tank. I am not sure that I installed it correctly. Does it push or twist into place? Such a wierd looking connector.
..........Rooster
rooster 2 is offline   Reply With Quote
Old 06-29-2004, 07:49 PM   #2
AudiSport4000
AudiSport4000's Avatar
Send a message via AIM to AudiSport4000 Send a message via Yahoo to AudiSport4000
Default Should just push into place
AudiSport4000 is offline   Reply With Quote
Old 06-29-2004, 08:05 PM   #3
SteveAngry
Default If it leaks...
you have to replace the tank.
You can't just replace the sender.
The wiring connector has nothing to do with the leak.
Steve
Michigan
1998 A6q
1986 5ktq: Megasquirt EFI and a lot of other mods your car probably doesn't have...
SteveAngry is offline   Reply With Quote
Old 06-30-2004, 02:14 AM   #4
Scott Miller
Default Plastic radiator repair kit
I fixed mine with Ankney's spare(thanks!), but have since fixed overflow tanks with the plastic radiator repair kit from Autozone. That's assuming it's a crack, not the connector.
'90 200qa - sold
'96 A4q 2.8l auto
'96 BMW 740iL
'97 FZJ80 Landcruiser
'06 Specialized Epic Comp Disk - daily driver
Holland, MI
Scott Miller is offline   Reply With Quote
Old 06-30-2004, 06:10 AM   #5
rooster 2
Default Thanks guys.........I appreciate the help and advise
connector, kit, overflow, plastic, radiator, repair, tank
