Old 05-22-2004, 07:46 AM   #1
fscskater
Default Whats this part called?
when I hook up the power to this part the after run system, or whatever it is, runs and doesnt shut off. So im thinking that this part is bad. Just wondering what its called or better yet if someone knows the part number.
Thanks,
fscskater
fscskater is offline   Reply With Quote
Old 05-22-2004, 08:02 AM   #2
QCRAZY
2000 Audi S4
My Garage
QCRAZY's Avatar
Default ..
Current Audi Count --- 5
Previous Audi Count --- 7
In spite of dealers; I still love Audi :-)
QCRAZY is offline   Reply With Quote
Old 05-22-2004, 09:30 AM   #3
ravidrabbit
Default Re: Whats this part called?
Water temp sender. There is also one on the top of te water hose outlet that i see it not connected. try hooking both of them up.
Jake (Mesa, AZ)
86 Audi 5000cs turbo (wifes)
81 Audi 5000s (my project car)
ravidrabbit is offline   Reply With Quote
Old 05-22-2004, 03:00 PM   #4
SteveAngry
Default That's the after run temp sensor...
Check your after run relay.
Steve
Michigan
1998 A6q
1986 5ktq: Megasquirt EFI and a lot of other mods your car probably doesn't have...
SteveAngry is offline   Reply With Quote
Old 05-22-2004, 03:43 PM   #5
QuikQtr
Default Re: That's the after run temp sensor...
Rad fan after run switch=triggers relay under dash (above drivers left knee). This relay has a built-in timer that should allow the fan to cycle on & off as told by the switch for a maximum of about 10 miniutes. If ign. key is cycled on and off again with-in this 10 min. period the timer cycle will start over!
QuikQtr is offline   Reply With Quote
Old 05-25-2004, 04:58 PM   #6
Rud67
Its a temp sensor of course of some sort it may have a different function for turbo and non turbo. It wasn' t used on later 86 5k non turbos, but did exist on earlier 86 5k non turbos. It costs about 8 dollars
Here is a link
http://www.autopartsworld.com/new/pr...5000&x=93&y=10
Rud67 is offline   Reply With Quote
Old 05-25-2004, 04:59 PM   #7
Rud67
Whoops here is the link or just cut and paste the previous[list][*]http://www.autopart
after, run, sensor, temp
