Old 07-08-2003, 06:10 PM   #1
sk88erguy
Default Brake test??
Hi I have an Audi 5000 S like I've said in recent posts and I have read a lot of different places about this, "being able to pump your breaks ten times before they lose power after the engine has been turned off." Now I can only do this pump about 2 times if that beofre I lose power. I just got them serviced with new pads and rotor turning and they feel great so is there anything i should worry about?
-93 S4, 08/92 build (1BE suspension)
sk88erguy is offline   Reply With Quote
Old 07-08-2003, 06:18 PM   #2
zsolt1
Default Yes! You need a new (AKA pressure accumulator)
Most likely you will not notice that you need it during normal driving conditions, however if you need to do an emergency braking, which is when you REALLY want to have your brakes working, you will notice that the pedal gets hard and you don't quite have the power to stop.
Cheers,
Zsolt
zsolt1 is offline   Reply With Quote
Old 07-08-2003, 06:20 PM   #3
zsolt1
Default oops I missed the word % " from my last statement.
= pressure accumulater
Old 07-08-2003, 06:21 PM   #4
zsolt1
Default ok, it doesn't let me write B0MB. This is a different kind so it's ok. :)
Old 07-08-2003, 06:22 PM   #5
sk88erguy
Default Re: ok, it doesn't let me write B0MB. This is a different kind so it's ok. :)
ok thanks for the help, how much and how hard is this to install?
Old 07-08-2003, 06:44 PM   #6
zsolt1
Default That's not a cheap item. I am not sure exactly...
maybe around $200 bucks, but it's not hard to install for someone who knows what he's doing. (I wouldn't want to do it, but I am no mechanic)
Zsolt
Old 07-08-2003, 11:16 PM   #7
moving violation
Default Re: That's not a cheap item. I am not sure exactly...
Do a search for "bomb", nearly everyone has done this. It is located under left side of engine compartment. There are three connections. acount for all washers. Pretty easy. Make sure to not lose any fluid also, it costs alot.
mike '875ktq
moving violation is offline   Reply With Quote
Old 07-09-2003, 09:15 AM   #8
audiqv8
Pump the brakes before attempting to remove the 'bomb' to relieve any built up hydraulic pressure
audiqv8 is offline   Reply With Quote
